Old 08-25-2018, 10:45 PM   #1
Steven67c10
Over heating problem
Hey guys, so I just bought a 69 c10. Truck has a 350 with aluminum heads and cam. Truck has a/c as well. Well when cruising down the highway at about 65 it’s at 3200-3300 rpm. It starts to go up pretty quick. When I noticed it going to 220 I slowed down and pulled off the highway. I’ve noticed it only does it when I’m on the highway and staying at or above the 3k rpm range. At idle and just cruising around town it stays at 170-180 all the time.
Any help on what I need to do to fix this problem. It has dual fans but maybe I need a bigger radiator. Maybe a new thermostat sensor?
Thanks guys
Steven67c10 is offline   Reply With Quote
Old 08-25-2018, 11:53 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Over heating problem
#1 cause for running hot at high speeds is a bad radiator. Getting it cleaned or replacing it should cure the problem.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 08-25-2018, 11:58 PM   #3
Boog
laying low
Boog's Avatar
Reducing the rpms will lower the engine heat as well. Either slow down or swap the rear end gears to a higher ratio will lower the engine heat. Or if ya got bucks, installing an over drive trans or gear vendors od unit will get ya there.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-26-2018, 12:21 AM   #4
Jcfcamaro
Jcfcamaro's Avatar
I'd say it's the radiator also. Buy a new aluminum one as it will cool alot better. ECP makes a real nice one. That's Engineering cooling products. Put one in my Camaro and all my problems went away.
Jcfcamaro is online now   Reply With Quote
Old 08-26-2018, 01:30 PM   #5
68 P.O.S.
Do you have a shroud?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-26-2018, 01:44 PM   #6
Jcfcamaro
Jcfcamaro's Avatar
Yes, My original radiator was taken to a shop and was redone. Had a shroud on it also, but would run hot. Everyone said to ditch the solid 4 blade fan and get a clutch fan so I did with no response.Even played around with different thermostats. Ended up buying the ECP radiator and all my problems went away. When I get closer to getting my 72 k10 with A/C I'm buying one for it. I have a factory radiator for it, but it would need sent to the shop to be tested/fixed and I'm not going down that path again and waste money.
