Old 08-26-2018, 11:28 AM   #1
Warrens69GMC
Warrens69GMC's Avatar
Rear axle options, 1964 GMC C2500
I have a friend who has a 1964 GMCc2500 longbed with leaf springs, and he is looking to upgrade the rear axle to a higher gear for better freeway driving.
Current setup per him-
1986 454
Th400
8 lug rear end, 5,13 gearset, leafspring perches
28 inch tall tires rear, 27 inch front tires
So we were thinking 3.55 or 3.73 gears, what can were use as a donar?
Maybe a 1973-1980 Suburban C20 with 3.73?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-26-2018, 11:58 AM   #2
LVPhotos
LVPhotos's Avatar
Re: Rear axle options, 1964 GMC C2500
3.73s and 28" tires. Everyone wants to do 75 but no one wants to spend the money on overdrive. My 81 did 3000rpm at 75 350/350 3.08s and 27 in tires
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-26-2018, 12:26 PM   #3
Warrens69GMC
I fully understand what you are saying.
Currently the 5.13/28/th400/2500rpms =40.6mph
Thinking the 3.73/28/th400/2500rpms = 55.85mph
Or maybe the 3.55/28/th400/2500rpms=58.69mph
Just trying to get an easy to swap gear from the 5.13 that is in it now. Overdrive may come later.
With a 4l80E-
5.13/28/4l80e/2500rpms-54.15mph
So the axle gearset has to change.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-26-2018, 02:07 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I'd convert over to a 14-bolt.
http://67-72chevytrucks.com/vboard/s...d.php?t=624445
http://67-72chevytrucks.com/vboard/s...d.php?t=550878
66 C20 Service Truck:
Old 08-26-2018, 02:10 PM   #5
LostMy65
LostMy65's Avatar
Oops, I'm sorry. I saw you already alluded to that at the end of your post.
Old 08-26-2018, 11:01 PM   #6
aotte1
You could also look at a 34” tall tire 255x85x16 tires on newer chevy 3/4 ton wheels(6.5x16) with the 4 nubs, around 1972. I have the toyo M55 tires in this size and they are 34” tall.
Les
aotte1 is offline   Reply With Quote
Old 08-27-2018, 12:20 AM   #7
Captainfab
60-66 Nut
With a 454 you could likely get away with a 3.08 gear. But finding a 14 bolt with those gears won't be easy.
Old 08-27-2018, 12:46 AM   #8
Warrens69GMC
What years for the 14 bolt? He wants a bolt in, no major mods to get it in.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-27-2018, 02:16 AM   #9
Killer Bee
Killer Bee's Avatar
what axle is in it now? I picked up a leaf sprung D60 out of a 66 gmc with 4.10 and limited slip for $400..
if it has a dana in it, carrier swap and gear choice of that range may be possible and certainly easiest fix..
I believe carriers change between 4.10 / 4.56 so 4.10 carrier or complete axle with one would take taller gears..
good luck!
Killer Bee is online now   Reply With Quote
Old 08-27-2018, 12:12 PM   #10
buds56
buds56's Avatar
Reaching into my memory so the measurements may not be 100%
Spring center bolt spacing on your gmc 40"
73 up square body C20 43" with a 6" tall frame center section
73 up C30 40" also includes all the 3+3 crew cabs with a 9" tall frame center section
But if you have a Dana 60 in it I would switch the gears and carrier and be done IMO
All those rears you'll find now are at least 40 yrs old and will more than likely need money put in them to make reliable. When I did mine the donor trucks were not very old and the GMC brake drums were scarce(early 80's)
Good Luck
buds56 is offline   Reply With Quote
Old 08-27-2018, 12:54 PM   #11
Killer Bee
Killer Bee's Avatar
^ good point there.. forgot about this thread where I found a bunch of similar info..
http://67-72chevytrucks.com/vboard/s...d.php?t=535453
post 8 in particular expands a little on what Bud posted above..
interested to see what's in there now, good luck!
Old 08-28-2018, 08:29 PM   #12
jdl71
jdl71's Avatar
good luck!
If it's original it's probably an Eaton HO52
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 08-28-2018, 09:50 PM   #13
Warrens69GMC
I contacted him to get me pictures.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-29-2018, 01:55 PM   #14
72cs20
If you are looking for a bolt-in swap, you may want to look at a Dana 60 from an 71-72 F250. When I converted my 65 GMC Suburban from 6 lug axles to 8 lug, I used a Dana 60 from an 72 F250 and it fit without modification to the spring perches. These can be had pretty cheap and there are plenty of gear choices available.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 09-01-2018, 06:20 PM   #15
LVPhotos
LVPhotos's Avatar
https://spicerparts.com/calculators/...rpm-calculator
Old 09-27-2018, 09:26 AM   #16
Warrens69GMC
pics
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 09-27-2018, 06:03 PM   #17
LostMy65
LostMy65's Avatar
Originally Posted by Warrens69GMC View Post
pics
That appears to be a Dana.
Definitely not an Eaton.
Old 09-27-2018, 11:54 PM   #18
Captainfab
60-66 Nut
That's a Dana 60.
Old 09-28-2018, 12:05 AM   #19
Killer Bee
Killer Bee's Avatar
^ yep, sure looks it
check the casting numbers to be sure.. carrier groups determine available ratio ranges..
axle spline are also relevant, but for the most part, Dana axles are fully supported in the aftermarket..
general info https://en.m.wikipedia.org/wiki/Dana_60
I covered some Dana info here, good luck!
http://www.67-72chevytrucks.com/vboa...48&postcount=8
