Old 08-26-2018, 08:13 PM   #1
jamie72
jamie72's Avatar
newer 8 lug rear
looking at swapping a newer rear axle in my 71 k20,any issuses? i need to change gears, and find a carrior for my old one but found a 2000 with rear discs and the right gears for way less.. i know i`ll have to move perches and shock mounts, anything else i`m missing?
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 08-26-2018, 09:00 PM   #2
jocko
jocko's Avatar
Re: newer 8 lug rear
Keep in mind a 2000 will have metric wheel studs and rear disks will require some master cylinder re-thinking.
Old 08-26-2018, 09:04 PM   #3
Bigdav160
Bigdav160's Avatar
Add changing gear ratio in the front axle to match the rear
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-27-2018, 04:21 AM   #4
jamie72
jamie72's Avatar
just bought the truck the 44 up front has complete rebuild..in 410 the back had some water in axle.. so the gears are rusty,and i want disc on rear..
jamie72
member #807
www.antlertalk.com
Old 08-27-2018, 06:59 AM   #5
062500hd
Track width is also different, wheels will look odd in the rear.
062500hd is offline   Reply With Quote
Old 08-30-2018, 04:41 PM   #6
72k20Farmtruck
They’ll actually look correct, old rear ends on the 4x4’s were narrower than the front. I swapped a 14 bolt rear out of an 02 chev and the track width matches the front.
72k20Farmtruck is offline   Reply With Quote
Old 08-30-2018, 06:20 PM   #7
57taskforce
All about them K’s
57taskforce's Avatar
Yep exactly also the American studs can be swapped in place of the metrics. I’ve got 2 disk 14s out of mid 00s trucks and I’ve swapped the studs already on one of them.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
