Old 08-26-2018, 10:11 PM   #1
chewychevy67
Any reason I can't use a stock water temp gauge for a trans temp gauge?
Can I use a factory water gauge wired the same way as the water gauge but put a oil sending unit in the transmission and use it to gauge oil temperature? I would have to get a sending unit for oil and not water temp I suppose. What should a th400 run for temp? Is this gauge going to be in the correct temp range for the tranny? Any insight on what sending unit that would be the correct ohms would be appreciated. The gauge is from a square body truck. Thanks in advance.
chewychevy67 is offline   Reply With Quote
Old 08-26-2018, 11:26 PM   #2
bill3rail
bill3rail's Avatar
Re: Any reason I can't use a stock water temp gauge for a trans temp gauge?
You asked the question I was in here to ask...What temp does the tranny run? Do some tranny research to find that information and you will answer it yourself.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 08-26-2018, 11:36 PM   #3
chewychevy67
Ok Maby I'm better to buy this and add a truck gauge face to it or have one made tat appears factory. Ive read 175 f to 225 f at normal operation. This way I can get to higher temperatures and it will still appear factory looking.https://m.ebay.com/itm/1981-1982-COR...UAAOSwsGdaoeUc
Old 08-26-2018, 11:48 PM   #4
weq92f
weq92f's Avatar
This pretty much jives with my limited experience as well. Drove a 2010 Tahoe for several years. It had tranny temp display in the dash if you knew how to find it! Despite high ambient temps and high speeds, the indicated never climbed above 195 that I observed.
Originally Posted by chewychevy67 View Post
... Ive read 175 f to 225 f at normal operation...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 08-27-2018, 01:35 AM   #5
68bowtie
68bowtie's Avatar
I have thought it would be cool to do this in the blank slot on the 7-hole cluster. If anyone works it out I would sure love to hear some details!
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Old 08-27-2018, 08:28 AM   #6
Red71gmc
Good idea. I'm staying posted on this one.
Red71gmc is offline   Reply With Quote
Old 08-27-2018, 09:04 AM   #7
chewychevy67
That's what I was thinking. Right now I have a vacuum gauge. Not sure how many times I've looked at it and wished a more useful gauge was there. I have a portable one for diagnostic work if I need.
Old 08-27-2018, 12:21 PM   #8
philB
I used same type temp. sender for both and used a toggle switch to send to either sender, worked for me.
philB is offline   Reply With Quote
Old 08-27-2018, 02:33 PM   #9
chewychevy67
Wow that's a good idea too
Old 08-27-2018, 11:11 PM   #10
chewychevy67
Did you use a sending unit from the engine in the transmission? If not what did you use and where did you locate the sending unit in the transmission?
