Old 08-28-2018, 11:37 PM   #1
jrpontiac
jrpontiac's Avatar
Hooker LS Turbo Manifold
Started my 5.3 turbo setup in my 77 c10 and wanted to post that the Hooker Turbo manifold fits a c10. It is very close and need a small amount of grinding here and there. Just wanted to post this so if people search in the future they can find it. Before ordering I called Hooker direct to see if they knew if it fit. They had no idea. You have to unbolt the passenger side motor mount and jack the engine up a few inches to get it in.
The grinding was on the clam shell mount mount portion. All else clears. I suspect with different motor mounts it would all clear.
1977 Chevy C10 SB, Turbo 5.3ls, TH400
jrpontiac is offline   Reply With Quote
Old 08-31-2018, 12:44 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Hooker LS Turbo Manifold
Cool, thanks for the info. I suspect no low mount a/c compressor will fit?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-31-2018, 11:16 AM   #3
jrpontiac
jrpontiac's Avatar
low mount AC compressor would not fit.
Old 11-25-2018, 01:24 PM   #4
BigRed76
BigRed76's Avatar
Do you have any updated pictures of hot side routing or turbo placement?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 11-25-2018, 01:35 PM   #5
jrpontiac
jrpontiac's Avatar
Hope to start up in a week or so. Waiting on the driveshaft and crossover pipe. Hot side pipe is to big. Used 3" id pipe. Would use 2" or 2.5" if I did it again.
Old 12-01-2018, 09:36 AM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Too freakin cool. What’s your intercooler setup look like?
-Chris
Old 12-01-2018, 10:22 AM   #7
jrpontiac
jrpontiac's Avatar
Here is a link to the build
http://67-72chevytrucks.com/vboard/s...d.php?t=771227
