Old 11-16-2003, 03:45 PM   #1
jorgensensc
jorgensensc's Avatar
Moving The Truck....Anyone done this?
For reasons I really can't get into, I need to find a Uhaul type vehicle to move my truck IN. I know I can move it on a trailer, but I need to move it in a closed type box moving truck. I measured it and it is less than 7 ft wide. Uhaul makes a 7'7" wide truck, but I'm concerned about the wheel humps inside of the Uhaul. Has anyone done this before and know of a specific moving truck that will work? By the way I have to do this myself, so car moving companies won't work.
Thanks for y'alls help once again!!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-16-2003, 03:55 PM   #2
Class of 69
Class of 69's Avatar
It sounds like you need a "dock truck" with the floor above wheel height. The problem would be getting the truck in, and out. A warehouse with a ground level door to drive in the warehouse, and a below grade dock to drive it in the truck would be the best bet.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 11-16-2003, 03:59 PM   #3
jorgensensc
Thanks for the suggestion Class of 69. Any suggestions on who carries those type trucks. I think ryder does, but I'm not sure. Uhauls trucks are only 2 ft off the ground, so I could make ramps for that. I know Ryders are a bit higher.
Old 11-16-2003, 04:07 PM   #4
Class of 69
Ryder is the only one I can think of, off hand too.
Old 11-16-2003, 05:01 PM   #5
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
i would check first.a buddy of mine used to work for uhaul and he rented a trk on sat morning and sat night we went to race track and the guy had rented it to haul his racecar in and it had damaged the truck well he ended up in court and had to pay for truck they said thats why they rent trailers and dollies.not trying to be smarta@@ or anything just a headsup because i dont think they allow it because there is really no way to chain it down so it wont move around
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 11-16-2003, 05:07 PM   #6
1969 GMC
1969 GMC's Avatar
also...you have a rear slider? if not, you will have an interesting time getting out of the truck with 7" clearance spread between 2 sides.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-16-2003, 07:36 PM   #7
67cst
i love summertime
67cst's Avatar
GMC-I was thinking the same thing, you might wanna pop your back window out unless you plan on sitting in the truck for the road trip! lol
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 11-16-2003, 07:44 PM   #8
Class of 69
I used to run OTR for a pet food co. We brought back lots of cars from Omaha NE, and Topeka KS, to the Twin Cities in the empty trailers for back haul. They just crawled out the side window, and nailed blocks to the floor to keep them from rocking back and forth too much.
Old 11-16-2003, 08:02 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
So let me get this straight.....
You need to move a truck.
It has to be enclosed inside, out of sight.
You have to do it by yourself, rather than using a company.
Sounds suspicious. Do you also need to know where to buy VIN number plates and rivets too?
Old 11-16-2003, 08:04 PM   #10
gonebad2
Merciless Butcher
gonebad2's Avatar
See if you can rent an enclosed car hauler trailer?? Just a thought.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 11-16-2003, 09:00 PM   #11
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
buy me a plane ticket, I'll fly out and drive it to Houston for you. If thats where you taking it to...
if you haul it enclosed, besure to account for the rocking movement back anf forth and side to side of the body inside the trailer. Unless you compress the suspension when hauling it...
tommie
tommie is offline   Reply With Quote
Old 11-16-2003, 09:07 PM   #12
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Sounds suspicious
Thats what I was thinking too. Just get a trailer pull it up on to it and put a tarp over it.
67Fleetsidedream is offline   Reply With Quote
Old 11-16-2003, 09:21 PM   #13
jorgensensc
Thanks for the input guys!!! N|o it's nothing illegal. I am moving back home and the military won't pay to move anything not in a truck, hence no car dollies or trailers. It doesn't matter anyway, I can't afford the 2300 Uhaul rental anyways. Thanks for all of your help anyways!!!
BTW, It takes a suspicious person to think like one!!!???!?? Ha Ha
Old 11-17-2003, 12:23 AM   #14
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The military won't pay for you to do it, however, if you just tow it out of pocket, they can't say anything.
Then if you tell them some one is driving it...they'll give you gas money.
C.I.D. hangs out at all the loading docks and the like...trying to sneak it by may get you busted if you want them to puck up on the bill to haul it.
Old 11-17-2003, 01:36 AM   #15
krazy_texan
krazy_texan's Avatar
only i will drive it wherever you want for bare minimum travel money
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 11-17-2003, 02:25 AM   #16
jorgensensc
Thanks for the heads up Longhorn man!!!
Krazy_Texan.
Thanks for the offer, but I am going to end up driving it back myself.
Old 11-17-2003, 07:10 PM   #17
Martin64
Martin64's Avatar
I hauled my old '71 Bronco in a U-Haul. The in-box fenders (U-Haul) are only about a couple inches high. I laid 2X6 blocks down and used them to ramp over the wheel wells. I cut wheel chaulks and nailed them to the floor and then cut longer boards to wedge between the back of the front tire to the front of the U-Haul wheel wells and then set the parking brake. Then I stacked the household stuff on top of, in the back of and behind the Bronco. I used the furniture cushions and blankets as padding so neither the Bronco nor the furniture would get messed up. It actually worked pretty good. But since the Bronco is much narrower it wasn't a problem climbing out the window once inside.
The aluminum box beds are just as easy to work with. You have to be a little more creative with your wheel stops because you can't nail them in, but you can build box type stops that wedge from the front wall to the front of the front tires.
I had to haul mine this way because I was in a real time crunch and there wasn't a trailer available. My wife drove her truck which we were paid both mileage and per-diam for along with per-diam for the kids....
I'll post a few pics when I can find them
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
