Old 08-30-2018, 10:36 AM   #1
daddybooz
daddybooz's Avatar
Exhaust manifold bolts in alum heads??
Guys,
Would like to inquire your thoughts on what to use on manifold bolts into alum heads. The obvious choice is anti-seize but that will vaporize at what +/- 900 degrees? Is a nickle based anti-seize a better choice?
Cant find any info on AC/Delco P/N 5613695 what they use on O2 sensors with glass beads in it?
Getting there, next stop, exhaust and get this finally driving!
Thanks for your input!
DaddyBooz
'68 C10 LWB
KCP 406; 400 small block, 30 over, alum heads built by Kurt Clapper
Ceramic center dumps, custom 2 1/2" SS all the way back w/MagnaFlows
2"/4" drop on 15's
daddybooz is offline   Reply With Quote
Old 08-30-2018, 12:49 PM   #2
cleszkie
cleszkie's Avatar
Re: Exhaust manifold bolts in alum heads??
I have always had good performance from the regular Loc-Tite brand anti-seize on steel manifold bolts in my Dart aluminum heads. Have never had a bolt seize or gall. I use the same stuff on my spark plugs with equally good results.
cleszkie is offline   Reply With Quote
Old 08-30-2018, 03:24 PM   #3
HO455
HO455's Avatar
The regular anti-seize will be fine. If the bolt threads on a N/A small block get to 900 degrees you will have lots more problems than bolts gauling their threads. There are high temperature varieties that would be called for in turbo applications.
RIP Bob Parks.
Old 08-30-2018, 05:32 PM   #4
Custom 68
Custom 68's Avatar
I have used anti-seize with copper (I believe) with good results. Just what the local parts store carries.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-30-2018, 05:36 PM   #5
mike16
no bolts. studs only, glue them in and try never to remove them. Coated stainless lubed with bee's wax on installation to avoid galling.
mike16 is offline   Reply With Quote
Old 08-31-2018, 08:32 AM   #6
daddybooz
daddybooz's Avatar
Thanks for replies. Motor builder says anti-seize will work just fine, guess I was over thinking it!
DaddyBooz
'68 C10 LWB
2"/4" drop on 15's
Old 08-31-2018, 12:35 PM   #7
Jrainman
Jrainman's Avatar
I was told a long time ago by some old time engine builders the best thing to use is Malox antacid liquid form yes ant acid you get from CVS /Wallgreens
Ive been using it for years on my cars, trucks and motorcyle exhaust. they built race engines and told me it has a higher heat tolorance then anti-seiz.
I just pulled off my motorcycle exhaust after 5 years that had aluminium heads and stainless studs and nuts and they came off with ease was it malox dono but it still had it on the threads after 5 years.
Jrainman is offline   Reply With Quote
Old 08-31-2018, 05:46 PM   #8
suprachrgd82
Farmtruck desciple
suprachrgd82's Avatar
Yup. Studs with brass nuts. No bolts.
suprachrgd82 is offline   Reply With Quote
Old 09-02-2018, 11:05 AM   #9
dirtyjim
dirtyjim's Avatar
yep Maalox or Milk of Magnesia have been used in high heat situations for a long time. put it on the bolt and let it dry then break off the excess
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
