Old 09-02-2018, 12:03 AM   #1
Curtb1971
Curtb1971's Avatar
72 AC cab and doors
Hey there, we have a cab from a project we recently picked up. It has had rockers, cab corners, floors patchs put in and also some work on the cab mounts done. The cab has been sand blasted and primed. The passenger side rocker needs redone due to fitment after we hung the doors. Radio is cut (have whole ac dash to fix for extra $75). No title. Has buttons around the rear window that could be ground and plug welded. Has paint divider rivets under rear windowm Passenger door is save able and drivers has been welded at the upper hinge. Both doors have speaker holes and have rust in the corners of inner skins. It would be a good start for someone that has a rusty cab. Have more pictures if needed. $SOLD cab and doors local pickup. Thanks, Curt
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 09-02-2018, 12:19 AM   #2
Curtb1971
Curtb1971's Avatar
Re: 72 AC cab and doors
Pics
Old 09-05-2018, 08:47 PM   #3
Curtb1971
Curtb1971's Avatar
I'm headed to Des Moines, Iowa at the end of the month and could bring this along if someone needs this in the Midwest. This cab was a NL2 (factory saddle gas tank) truck and still has the holes for the tank valve and gas gauge switch.
