09-02-2018, 12:52 AM | #1 |
60-66 Nut
High Hump
I just ran across this while looking for something else. I did not realize that steel high humps were being reproduced. They must be fairly new. I see that complete firewalls are now available also.
https://www.classicparts.com/1960-63...ctinfo/40-416/
09-02-2018, 05:01 AM | #2 |
But Found Her 25yrs Later!
Re: High Hump
Nice find.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-02-2018, 07:21 PM | #3 |
Re: High Hump
I know there is a vendor working on doing a high hump and the firewall part. Not sure where they are in the process.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-02-2018, 11:31 PM | #4 |
60-66 Nut
Re: High Hump
09-03-2018, 12:47 AM | #5 | |
Re: High Hump
09-03-2018, 10:58 AM | #6 |
Re: High Hump
Clarification on the high hump...whats the need for it...?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
09-03-2018, 08:08 PM | #7 |
Re: High Hump
Nope one of big the metal guys. I supplied them with a high hump and the fire wall piece. They planned to scan the pieces and see if they could start making them. They have the resources to do it.
Jimmy
09-04-2018, 12:19 AM | #8 |
60-66 Nut
Re: High Hump
The SM420, SM435, SM465 and most newer OEM and aftermarket 5 and 6 speed transmissions need the room.
09-04-2018, 12:20 AM | #9 |
60-66 Nut
Re: High Hump
Is it someone that will make them domestically?
09-05-2018, 11:30 AM | #10 |
Re: High Hump
I think they will be out of one of the Taiwanese plants. They are a big supplier of body parts and the resources to get stuff done.
Jimmy
09-05-2018, 11:52 PM | #11 |
60-66 Nut
Re: High Hump
The high hump cover I posted a link to is likely made by that supplier.
09-06-2018, 10:52 PM | #12 |
SAVING ONE TRUCK AT A TIME
Re: High Hump
Interesting. Great find.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
09-08-2018, 10:44 PM | #13 |
Re: High Hump
I just received my trans cover today from classic parts and it is not the high hump. From the picture in classics site its hard to tell. I'll give them a call on Monday and see if the high cover is available.
09-09-2018, 05:37 PM | #14 |
Re: High Hump
Would you be able to post a pic of the hump you got?
09-09-2018, 08:10 PM | #15 |
Re: High Hump
Here are a couple of pics of the trans cover. It seems well made just not tall enough.
09-09-2018, 10:17 PM | #16 |
Re: High Hump
OK, I'm not a metal fabricator. But I was looking at what the PO had done to get the trans to clear (first Picture).There are some really good fabricators on this site and I was wondering if anyone has modified their low hump like this? It might be a bit of work but I thought it might work pretty well.
09-10-2018, 12:03 AM | #17 |
60-66 Nut
Re: High Hump
So it isn't a high hump as it appears in the pics......I stand corrected.
09-10-2018, 12:11 AM | #18 |
Re: High Hump
the picture was not very detailed. Since I have not found another high hump I was thinking of modifying mine as pictured.
09-10-2018, 12:17 AM | #19 |
Re: High Hump
A friend of mine has a 68 Gmc with factory th400. If I remember correctly it has a high hump. Did gm make the high hump a standard for all transmissions in the 67-72 years?
09-10-2018, 12:54 AM | #20 | |
Re: High Hump
Good luck with the project, Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
09-10-2018, 11:47 PM | #21 |
60-66 Nut
Re: High Hump
No, the '67-'72's had both low and high hump trans covers.
04-05-2019, 11:28 PM | #23 |
60-66 Nut
Re: High Hump
I see that they also have one with no holes, which is nice. However the one review on this cover is not good.
04-05-2019, 11:59 PM | #24 |
Re: High Hump
I just saw that review. Looks like only part of the 2 piece high hump...wonder why they don't make the upper portion?
04-06-2019, 11:37 PM | #25 |
60-66 Nut
Re: High Hump
The forward section would be difficult and quite expensive to reproduce. I doubt that people would pay the kind of money a quality steel reproduction would cost when the Slosh Tubz fiberglass version is available.
