OEM air cleaner size/dimensions for 1983 GMC pickup?
We just got back from a trip to Tennessee. While we were there, we looked at my great-grandfather's 1983 GMC Pickup C1500 Wideside pickup (trim level High Sierra).
One thing I noticed right away it that the truck is missing its air cleaner assembly. I'm hoping that nothing detrimental got down inside the engine through that hole. I'm guessing that, once we get it back to South Carolina and begin working on it, we may need to partially disassemble the top of the engine and clean it out before attempting to start the engine? On a different note, does anybody have any idea how to find out the dimensions of the OEM air cleaner? AutoAnything lists several sizes for its cheapest Edelbrock air cleaner: https://www.autoanything.com/air-fil...lo-air-cleaner Would this one from Summit Racing (https://www.summitracing.com/parts/e...IaAsfNEALw_wcB) fit a 1983 GMC Pickup C1500? This truck has a 5.0 L (305 cu. in.) engine and a 4-barrel carburetor if that helps. |
Re: OEM air cleaner size/dimensions for 1983 GMC pickup?
Those two won’t bolt right on.
Might be too big in diameter and hit the distributor cap. Factory air cleaner had a recess in it so it would fit. Other thing you need for those 4 barrel types is an adaptor to fit your 2 barrel carb. Yes, that’s right. You have a 2 barrel. Looks like a Rochester 2GC. Might be easier to find a stock one. If you’re worried about something getting inside, just until you try to fire it,just cover the carb with tinfoil. It’ll mould right into place easily. Last edited by geezer#99; 09-02-2018 at 09:18 PM. |
#3 | |
Never seen a vin that said what carb you got.
Type of motor though. And yes it’s a Rochester 2 barrel. A 2 jet or commonly called a 2G. Pic of one here. https://quadrajetparts.com/ |
#5 | |
Maybe your intake/carb or complete motor was changed.
If you look behind the alternator and in front of the head you’ll find a flat pad with some letters and numbers on it. There’ll be a suffix code there. Find that and we can help you narrow it down. There’s also a casting code behind the drivers side head which will help further. And a casting date at the back too. And thanks for teaching me something. I didn’t know I could decipher the vin like that! Last edited by geezer#99; 09-02-2018 at 11:54 PM. |
Yep, sure looks like a 2 bbl. Guessing the original Q-jet developed a problem and was replaced with something that was available just to get it running.
After looking at your down the carb pic, looks like at least one of the venturi tubes is mostly plugged. Give the carb a good cleaning before attempting to start. While the carb is off, pull the plugs and give the cylinders a good spray with penetrating oil. Then use one of those air compressor spray ends with the rubber tip and blow into the plug holes. If you get piles of mud dobber nest bits, you have your answer on need to pull the intake before starting question. Assuming the throttle plates stayed closed all the years it sat, shouldn't be too much debris in the intake and cylinders. |
#8 | |
I'll definitely look for those codes once we can bring the truck from TN to SC. You're welcome! I just did a Google search for "general motors vin decoder," and the link I sent you was the second result. |
can you legally get this truck on the road in sc. changed cabs and frames sometimes create night mares. Serial numbers don’t match.
You could just end up with a parts truck. In case I lose this thread, here’s some info on motors. http://www.nastyz28.com/decode.html And one with casting numbers and locations. https://www.mortec.com/ Last edited by geezer#99; 09-03-2018 at 11:29 AM. |
#10 | |
If you have concerns along these lines then post a new thread. This thread's content has moved well beyond its title. I doubt very much that your truck will be relegated to parts status. Back to the air cleaner: I have an '82 with an intact 305 4 barrel. They came with gigantic air cleaners like the big-block engines, at least my high-output LE9 engine did and I've seen other similar ones. You'll probably need something like this: https://www.speedwaymotors.com/2-Bar...ase,36140.html Unless you replace some parts per below. Based on it sitting open like that I would pull the carb off to clean it and if you are hoping to use this engine without a rebuild I would pull the intake manifold and heads and clean everything down to the top of the pistons and then make sure the crank rotates and the pistons move freely. Ask more about that in a new thread if you don't have familiarity. Finally, since you will have the carb and intake off I would replace them with a 4 barrel setup. Good luck and post some pictures of your truck! |
