![]() Join Date: Jun 2010
FINALLY got my new brake lines done!
I am redoing all of my brake lines in stainless. I bought a complete set of lines from Right Stuff Detailing a few years ago and finally started installing them in August. The rear lines were not right, and the proportioning valve lines were not right as I am using a 3/4 ton brake booster and master cylinder. I tried another set of rear lines from Right Stuff and the new ones were exactly the same (wrong). I called the company and they were not much help. They did refund my money for the second order, but they argued with me about the small lines to the master cylinder. The guy told me they don't do much with older trucks.
So I called Inline Tube and bought a new set of rear lines and a partial front line set that also includes some of the front lines that I don't need but they don't sell just those small lines. I put them all in yesterday and they fit perfectly! Here are some pictures:
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 09-03-2018 at 09:21 AM. |
Re: FINALLY got my new brake lines done!
I replace my entire braking system last year with the restoration since it sat so long with previous owner.
Even added rear disc. Little shop manufacturing economical swap, FYI Anyway. I used pre bent stainless lines from inlinetube $180 for all the lines and they fit perfectly. I had question on the prop valve and their customer service was fantastic. took about 2 hours to take off old lines and install the stainless. I highly recommend them.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
![]() Join Date: Aug 2015
just replaced mine from inline tube,all lines and all 3 rubber lines, everything fit perfectly, absolutely no issues, only problem is the pressure clip that holds the rubber brake lines connection tight were broke, have to buy a couple tomorrow, good luck
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
I am doing the same, but i am looking at your master cylinder to proportioning valve and it looks as if they are reversed, or switched. Now i could be wrong, but from everything i have seen, read and done, the front port on the master cylinder is for the front brake port on the proportioning valve and it looks like you have the front port on the master going to the rear port on the proportioning valve. I just would not want you to get all the way down the road and find out then.
I was just looking at that yesterday and then saw a friend's truck that is set up opposite of mine. It's a 3/4 ton booster and master cylinder, maybe that is what's different?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 09-24-2018 at 12:36 AM. |
![]() Join Date: Oct 2009
1/2 ton mc: front res is for front brakes
3/4 ton mc: front res is for rear brakes |
Thanks, Jocko. I thought I saw that somewhere. I hope I don't regret putting the 3/4 ton stuff in there,
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
I foolishly didn't retain my original lines I bought inline stainless a few years ago trying to install the only thing I can figure out is the rear end and the frame run up to the front. The stuff they gave me for the master and front end are way off.
I would think there are some people on here that have a truck with out the motor in it and could send you some pictures of the routing
Old member
I just bought the easy roll brake line and fuel line kits and ran everything myself. $25.00 for like 30ft of tubing with all the connections you need. I ran it all in about 4 hrs one day.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thanks for the pictures I was looking at the copper nickle Nicopp line some reviews on amazon says it's too soft to get a flare that doesn't leak they had to go buy a spool of steel line. Then I read bad reviews on the steel line that it was very difficult to bend but the flaring was easy. I think I'm going to try the nickle copper the inline stainless kit is not going to work up front. I converted to a BBC with 2" primary tube headers that is interfering some where the lines turn up toward the master.
#12 | |
Old member
![]() Quote:
#13 |
Looks nice I have the CPP brake master and booster.
