Old 09-03-2018, 05:35 PM   #1
mehoff400
slop in steering
i cant pin point what is wrong with my steering. some say its possible rag joint others say it can be the steering box. here is a video any thoughts?
https://youtu.be/9Pai-rp7E1M
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 09-03-2018, 06:11 PM   #2
62bagger
62bagger's Avatar
Re: slop in steering
from what I can see from the video it looks like the steering box. The shaft turns but the pitman arm does not move.
62bagger is offline   Reply With Quote
Old 09-03-2018, 07:37 PM   #3
ImpalaJim
ImpalaJim's Avatar
My vote is steering box also
ImpalaJim is offline   Reply With Quote
Old 09-03-2018, 07:37 PM   #4
COCONUTS
COCONUTS's Avatar
Definitely the steering gear box. You can get a remanufactured one with a lifetime warranty pretty reasonable. Be sure to change the rag joint while you’re at it. I just finished this on my 66. Check prices at parts houses like Rock Auto or Advanced Auto. Advanced has a 25% off coupon deal....I used it for my Saginaw steering gear box. The restoration places charge too much.
Now on to the suspension for me...
COCONUTS is offline   Reply With Quote
Old 09-03-2018, 09:31 PM   #5
mehoff400
yea i thought so... i guess installing power steering is coming sooner than i thought.
Thanks for the help
My truck
Old 09-04-2018, 07:48 AM   #6
nsb29
nsb29's Avatar
Power steering is great but there is an adjustment screw with a lock nut on top of your steering box if you loose in the lock nut and then tighten the screw while rocking your steering wheel back-and-forth until the play is gone then retighten your lock nut will solve your problem this is very common with older boxes
nsb29 is offline   Reply With Quote
Old 09-04-2018, 12:06 PM   #7
mehoff400
Tighted the nut didn't do anything
My truck
Old 09-04-2018, 02:57 PM   #8
WhippinSaw
WhippinSaw's Avatar
Had my steering box rebuilt for 200$ at a local gear shop. Was not sure if I could find a new exact replacement so I went rebuilt.
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
