09-03-2018, 06:36 PM | #1 |
Rust on the inside of main caps in rear end
Kind of new to doing rear ends and am unsure what to do about this. Upon disassembly of a GM 12 bolt I have found some rust on the inside of the main caps. My question is should I just lightly sand the rust off or is the rear end junk now?
09-03-2018, 07:21 PM | #2 |
Re: Rust on the inside of main caps in rear end
I'd lightly sand it. Very lighlty. You need to make sure it doesn't lose surface area contact to the bearing race. I'd also get a piece of glass and sand the mating surface of the caps as well to slightly tighten it up.
Place glass on table, place sand paper on glass, pass mating surface of cap across. Maybe 4-6 passes on 120 grit paper.
09-03-2018, 07:31 PM | #3 | |
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
09-03-2018, 11:19 PM | #4 |
Thank you for clearing that up I didn't really know what to do there. I sanded them with 400 grit and they have a nice shine now. Hopefully it works and nothing breaks.
09-04-2018, 08:44 AM | #5 | |
I’m not a full time diff guy, but I have built well over 30 including installing steel caps on OEM housings. So my comments are based on some experience. But as usual, YMMV.
09-04-2018, 10:15 AM | #6 |
Not trying to hijack, but what does this do? I have never heard of using glass, is it just to provide a nice flat surface?
1972 C-10 [Boppa's Truck] |
09-04-2018, 10:36 AM | #7 |
Yes, it's also what you use to flat surface thermostat housings that leak ,A flat sheet of sandpaper laid on the glass gives a smooth even surface . On the bearing caps to remove surface rust using a scotch brite pad is fine ,Your not going to remove enough metal to affect anything It's the cap Not the bearing race, Having rust in the bearing cap just shows at some point there has been moisture inside the housing and changing out the axle bearings/race at the same time would be a good idea .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
09-04-2018, 12:01 PM | #8 |
I'd not use any sand paper, a scotcbrite pad or better yet steel wool will o the job and have zero chance of damaging anything .
There are many rust removing solutions available, I use phosphoric acid diluted in water 3>1 with steel wool or scotchbrite pads to easily return to shiny metal.
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
09-04-2018, 10:35 PM | #9 |
Something I just learned on this rebuild is that vinegar does a good job of removing rust if you can soak it overnight at least. Then you can wire brush it off.
1968 SWB Step Side, Big Block, 4L80E , Running! |
09-05-2018, 12:00 AM | #10 |
Yes but ;
Vinegar will flash rust as you rinse it off .
