Old 09-03-2018, 08:29 PM   #1
smith
smith's Avatar
Heater valve question
I’m trying to attach a pic of what I think is the valve that is supposed to be activated by the hot/cold lever on the dash. I don’t think mine is hooked up right but that is ok. I just want to set it in whatever position is cold so no coolant is flowing to the heater core. In this pic the lever appears to be in the “out” position. The “in” position move it in only about 1/4 to 1/2 inch. Anyone know which setting closes this valve?
Dan Smith
1971 Jimmy
smith is offline   Reply With Quote
Old 09-04-2018, 09:22 AM   #2
JackB
Re: Heater valve question
Valve in pic closes with vacuum applied. Its currently in the open position Looks like maybe there is no vacuum line going to it. There is a vacuum port attached to the hot cold lever on the dash that dictates whether the valve gets the vacuum it needs to close. You can chase down the vacuum lines and get it all working properly or just replace the existing valve with one that you open and close manually like the one below
JackB is offline   Reply With Quote
Old 09-04-2018, 02:02 PM   #3
rpmerf
rpmerf's Avatar
I believe when you move the top lever all the way to the left, it closes the valve and sets the re-circulation stuff. There is a vent door on the pass side floor board that opens. On top of the HVAC box under the hood, there is a flap that closes to pull air from inside rather than outside.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 09-04-2018, 06:03 PM   #4
smith
smith's Avatar
Where can I get that valve from? Know what size? Thanks
Dan Smith
1971 Jimmy
Old 09-04-2018, 06:57 PM   #5
JackB
Any auto parts store would have them. Heres one from Napa. https://www.napaonline.com/en/p/BK_6601414
The size can be 5/8 or 3/4 depending on which hose you choose to put it. The original is on the 5/8 line.
Old 09-05-2018, 10:37 AM   #6
smith
smith's Avatar
Thanks. Probably a good time to flush the radiator also while I'm doing that-its been a very long time.... Anyone know the capacity for a coolant stock system with a 350?
Dan Smith
1971 Jimmy
