Old 09-04-2018, 11:13 AM   #1
lofly'a
lofly'a's Avatar
Question OBD code 21 & 87
My 94 Cheyenne 350/4L60E has 2 codes, 21-TPS signal high, and 87-EEPROM flash memory error. On 21, I changed the TPS (housing was cracked) before it had this problem, and all was well for a short time then truck started stumbling off-idle and idling high. Also What are effects of 87? No vacuum leaks, no miss, just hesitation & high idle. I notice a difference in shift points also. Anybody?
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 09-11-2018, 03:23 PM   #2
mikebte
Re: OBD code 21 & 87
Still having the issue?
Have you tried hooking up a vacuum gauge and seeing whats it says?
Saw this on another post, may help you get started. Hesitation can be a few things but good to start with a vacuum gauge.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
Old 09-16-2018, 01:58 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Check the 10 amp fuse in the fuse panel labelled Trans...87 code can be set if this fuse blows...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2025 Chevy Equinox
AussieinNC is offline   Reply With Quote
