Old 09-04-2018, 11:28 PM   #1
4x4k30
4x4k30's Avatar
how to adjust the steering gear
what is the proper way to adjust the steering gear ? I have tried to turn it both ways and just cant get it to where it feels rite
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 09-05-2018, 04:58 AM   #2
Wgesnerjr
Wgesnerjr's Avatar
Re: how to adjust the steering gear
try this: https://youtu.be/W5Ck4eANgII
Just did this and found an 1/8 of a turn helped a lot. no where near rack and pinion feel, but better with less of a dead spot in the center.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 09-05-2018, 12:46 PM   #3
Keith Seymore
Keith Seymore's Avatar
It's spelled out in the "Unit Repair Manual".
Basically, you are supposed to remove the gear from the vehicle and mount it in a vise.
Using an inch pound torque wrench you rotate the gear at the input shaft and measure throughout the rotation.
The baseline measurement is called the "preload" (or "ends") and is adjusted by the big nut surrounding the input shaft. It should be adjusted to 12 inch pounds.
The measurement taken at the straight ahead location is called "overcenter" and is supposed to be 20 in lbs or so. It is adjusted with the allen screw with the locking nut, located on the cover.
Or - you can just leave it in the vehicle and crank the allen screw like everybody else.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-06-2018, 07:18 AM   #4
K
Old 09-06-2018, 12:06 PM   #5
4x4k30
4x4k30's Avatar
i guess either way i will wind up replaceing this steering gear i found one that was off a 86 m1008 that i had .and i am just gona put it on and hope for the best.
Old 09-07-2018, 08:15 PM   #6
v30crewcab
v30crewcab's Avatar
the top nut adjustment is the "last" adjustment made, after tightening the top where the steering shaft hooks up. read the writeup in the manual, and do it right. my trucks drive like new when I'm done adjusting them by the manual.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 09-10-2018, 06:30 PM   #7
4x4k30
4x4k30's Avatar
see video https://www.youtube.com/watch?v=Gl-Z_TrM18c the steering gear pitman arm goes up and down and pops will a adjustment take that out ??
Old 09-10-2018, 07:57 PM   #8
cadillac_al
That looks pretty bad. I have never had one anywhere near that loose. I'd be buying a new/rebuilt one
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 09-26-2018, 08:53 PM   #9
4x4k30
4x4k30's Avatar
well I put on the m1008 steering gear it lasted about 2ft when the front seal blew out . I checked every thing when I first put it on let me tell its a real pain in the but to do it by ur self . the steering gear was not leaking at all until I got in today to drive it.
