09-05-2018, 04:19 PM | #1 |
[Challenge] Emergency / Parking Brake Setup for modified 1964 C10
Dear board members, I'd need some help solving a technical challenge I have with my truck.
First, a bit of info about the truck/drive train:
My (current) challenges regarding the parking brake: (1) there's only one "loose" cable; the one from the lever ending under the cab. The rearend has only martially cut cables on both sides (5-7" long or so). Nothing else really. No connectors, equalizers, hooks...nothing. Unless I've overlooked/forgotten something. (2) I have no decent suppliers for US (truck) parts locally. Thus, I would need/like to build up almost everything from scratch with (new) parts from the US. I'm in contact with Inlinetube regarding this issue, but they struggle a bit with my drive train combo. They're very cooperative though and are working on this (too). My initial idea was to somehow combine 64-66 C10 front cables (LMC diagram here) with rear cables for the 12 bolt (LMC diagram here), but apparently that's not a walk in the park. The fact that I'm not familiar with the original e-brake setup for the truck doesn't really make this easier. But I'm ready for the challenge. With your help. |
09-05-2018, 04:45 PM | #2 |
Moderator
Re: [Challenge] Emergency / Parking Brake Setup for modified 1964 C10
This place claims they can make anything you want - http://www.controlcables.com/
09-06-2018, 12:06 AM | #3 |
60-66 Nut
I don't have any idea what you used for a trans crossmember but with what you have in your truck I would convert to the '66-'72 e-brake cable system, including the cables from the backing plates. Since your truck has leaf springs (I assume you have a GMC) there should be brackets on the bottom of the frame near the front of the leaf springs.
09-06-2018, 01:08 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
LMC pg 41 of 60-66 Chevy truck catalog. Right side of page, shows the 66-72 ( I think that’s right) emergency brake setup in picture form.
If you purchase as a 66 then you should get the right parts to get your emergency/parking brake setup functional. http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=41 I used this on my 65, works great!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-06-2018, 03:28 PM | #5 | |||
For instance, the 84-87 e-brake setup (2nd attachment) seems to be quite simple in comparison. |
09-06-2018, 04:47 PM | #6 |
That’s a 65 c10 crossmember
Looks like this is same for the GMC with leaf http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=41
09-06-2018, 06:14 PM | #7 | |
I basically have the same issue, I have the front cable from the cab to the center, then the 2 cables going to each of the wheels. With no clue how to connect them.
Been a crazy 2018. Moved twice, back HOME in Oregon. Now to put everything back together, including the truck... My build thread for "Rocket" - http://67-72chevytrucks.com/vboard/s...d.php?t=753023 |
09-06-2018, 07:59 PM | #8 |
I made the clip things that connect the rear cables to the intermediate cable. I did retain my original main cable from the handle to the intermediate cable. The ones I got from China didn’t hold up past two pulls.
I used some steel from an old bumper, drilled the holes and bent them like they are shown in that picture in the link. They are made now!! https://www.classicparts.com/mobile/...info/71%2D894/ Tensioner: https://www.classicparts.com/mobile/...info/71%2D770/ More parts: https://www.classicparts.com/mobile/...info/71%2D880/ Hope that helps!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 09-06-2018 at 08:04 PM. |
09-06-2018, 11:45 PM | #9 |
60-66 Nut
Surprisingly enough you have the correct factory trans crossmember for a '63-'65 truck. The factory '63-'65 e-brake cables and related parts will only work if the trans crossmember is in the factory location. However I doubt that it is given your engine and trans combination. In light of that, I still think that converting to the '66-'72 assembly will be the best idea. But given that the rear leaf springs are not original, some modifications may be necessary to connect the intermediate cable to the cables going to each rear wheel.
09-07-2018, 07:54 AM | #10 |
It is indeed the correct crossmember but there are some parts missing. In the original setup the cables are running against the trailingarms to the rear breakdrums. You only have to find a way to get that cables to the breaks with the leafspring setup.
I think the diagram of the parking brake system in the LMC catalog is not the same for every year. Last edited by BabyBlue64; 09-07-2018 at 08:34 AM. |
09-07-2018, 12:20 PM | #11 |
meowMEOWmeowMEOW
Maybe its cheating...but why not a hydraulic brake lock? Not sure about drums, but it works as a cheater ebrake on discs.
http://www.amazon.com/Park-Lok-Unive.../dp/B01N9VOQTJ
09-07-2018, 12:21 PM | #12 | |
I can see how the little connectors you linked would connect to the rear cables, but I'm still confused to see how it would be mounted, and where the tensioner connects. Any way you could get some pics of how your setup is constructed underneath your truck?? pretty much just how the OG front cable is connected to the mid, and then mid to the OG rear cables. Thank you sir!
09-07-2018, 12:40 PM | #13 |
64,
I will try to get the pix, this weekend is a crazy one tho. The links I posted have the supporting cables/hardware that hold the intermediate cable suspended while the cable attached to the lever in the cab pulls to activate the parking brake at the wheel.
09-08-2018, 03:36 PM | #14 |
Good input guys. A huge thank you for that.
I'll take a closer look at the '66-'72 setup and invest some thoughts how it could work out in my truck. While we're at it...how are those cable guides or hooks or whatever they're called mounted? Are they simply hooked in some holes in the frame, or...? The guys from Inlinetube also had some idea. I'll hopefully get their plans this weekend. In terms of customer care, they've been fantastic so far. Last edited by nibulus; 09-08-2018 at 03:42 PM. |
09-08-2018, 04:05 PM | #15 |
Most are hooked through a hole in the frame, the main one is on passenger side, goes through frame and bolts there, I believe that is adjustable.
The parking brake guide kit I posted is all you need other than the cables.
