Old 09-06-2018, 01:33 PM   #1
Kudzupatch
Kudzupatch's Avatar
Before and after wheel polish
I have been looking for a new set of wheels for a while but couldn't settle on what style I wanted. Finally just decided to keep these for a while.
I accidentally got some carb cleaner on one of the wheels and it stripped the clear coat off in spots and looked terrible. I have debating on stripping and polishing these for a while and since I had to have new tires put on the next day I decided it was a good time to strip and polish them.
Hubs come out mirror like, a bit to much so. The wheels because of the machine finish don't have the same shine but man do they look better.
Used Orange stripper and the clear coat came off very easy. Just keep it wet and when everything is loose just hose it off. Just don't rush of you will have spots you will have to do again.
Then I used Mothers aluminum polish, by hand. They are so clean it took very little to get a shine on them. You could work these to a mirror finish you wanted. You would have to work down the machine grooves in the wheel with a powered polisher and some abrasive polish. I put a coat of paste wax over that and I was done. 45 minutes to do one wheel from taking it off to back on the car.
They will be more work to keep looking good but I don't mind and I won't let them go to long between cleaning.
Kudzupatch is offline   Reply With Quote
Old 09-08-2018, 07:27 AM   #2
Re: Before and after wheel polish
Came out good. I have seen others get them looking really good, but as you are seeing it is a LOT of manual work.
Old 09-08-2018, 09:34 AM   #3
Kudzupatch
Kudzupatch's Avatar
It only took 45-50 minutes a wheel, including taking them off and installing. So I wouldn't call that a lot of work.
Now to polish the aluminum one to a high gloss, yes, that would be a lot of work.
Old 09-10-2018, 03:38 PM   #4
Stormin08
Stormin08's Avatar
My daily driver is an 02 cummins ram...i used aerosol aircraft stripper (while sitting at the local coin wash), 15 minutes later rinsed with the power washer and done.
Then used mothers and power ball, they look better than the factory chrome covers.
Stormin08 is offline   Reply With Quote
Old 09-11-2018, 01:47 PM   #5
Tom
driving is in my blood
Tom's Avatar
Exactly, forget all that manual polishing
