Old 09-07-2018, 12:18 AM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
Under bed fuel tank
Hi folks so I got my tank mounted I think I can tackle the fuel lines by my self. What I think I'm gonna need guidance with though is centering the fill tube on the wood. Once the bed is mounted. Any tips is greatly appreciated. Thx
1966FLEETSIDE is offline   Reply With Quote
Old 09-07-2018, 06:53 AM   #2
PGSigns
PGSigns's Avatar
Re: Under bed fuel tank
Here is how I did mine when I installed my boyd tank. I measured from each of the frame rails to the neck to find out how far the neck was fro center. Then I used that measurement to find out what board it would under. I removed that board and put the bed back on. Centered up the bed using the mount bolts and by eye. Then took tape and put it on the boards on either side and put reference lines on it. Took measurements from the reference lines to the center of the neck. Dropped the board back in and transferred those measurements to the board to lay out the center point and used that to drill the hole with a 3 1/2" hole saw. Worked like a charm.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-07-2018, 07:53 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
I've been pondering this myself. My plan is to use a short flat pencil from underneath. Then remove the board for cutting. It'll be tight but I think I can do it.
Will it be more difficult that way? You bet, but I think it will be the most accurate. Only time will tell.
Old 09-07-2018, 10:31 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
I don't like attaching a filler neck to the bed floor...I usually do an access door. Similar to PGSigns, I made reference measurements, located the board, and made the cut out for the door. Here's a before and after.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-07-2018, 11:15 AM   #5
mongocanfly
Post Whore
mongocanfly's Avatar
Or put all the wood in the bed floor except the piece where the filler is....use a sacrifice piece short board to determine where the hole needs to be...once you get it like you want ,then transfer that to your good board...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
