Old 09-07-2018, 11:56 AM   #1
rollin thunder
rollin thunder's Avatar
How to identify transmission and what fluid?
I am getting ready to put the transmission and engine together and into the truck. The only problem is I am trying to find out what type of fluid to use in the transmission and how to identify it.
Its the original 3-speed manual transmission out of my 1984 C-10.
This is the only picture I have of it at the moment. I can get some more later today after work if i need to.
Thanks in advance!
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373
1984 Chevy C10 short bed
2001 Chevy Impala police cruiser
2001 Chevy Silverado 1500 Z71 4wd extended cab dd
rollin thunder is offline   Reply With Quote
Old 09-07-2018, 03:52 PM   #2
Re: How to identify transmission and what fluid?
80w or 90w gear lube. Can find it most anywhere, Walmart to parts stores
Old 09-07-2018, 03:56 PM   #3
rollin thunder
Thank you!
Old 09-08-2018, 01:27 PM   #4
GRADYS Performance
GRADYS Performance's Avatar
Go to Amsoil.com and you can put in your truck info and it will show the recommended lube and volume to use.
GRADYS Performance is offline   Reply With Quote
Old 09-09-2018, 12:38 PM   #5
hatzie
Moderator
hatzie's Avatar
Saginaw 3 speed.
No need to use designer oil in your trans. Dinosaur squeezins should do just fine. 1.5 Quarts of 80W90 GL-5 Gear Oil is what GM lists on Page 0B-7 of the 1984 light truck service manual... capacities are on page 0A-6.
There are several writeups on how to adjust the column shifter.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-10-2018, 04:33 PM   #6
rollin thunder
Originally Posted by hatzie View Post
Saginaw 3 speed.
must be the technical term. As for the column shifter I’m sure it will need some adjustment. Towards the end of when I last drove it I started to have some issues with it getting hung up.
