09-07-2018, 11:59 PM | #1 |
Revitalizing a 6T C10
horse-shoe small block engine mounts / oil pan
Hey All,
my truck has a (non original) v8, using the original type horse-shoe v8 mounts, and I am looking at doing the oil pump this weekend ... does anybody know if the pan will come out without lifting / pulling the engine? 2nd question - do I have to pull the starter to pull the pan? Thanks guys!! |
09-08-2018, 01:00 PM | #2 |
Re: horse-shoe small block engine mounts / oil pan
I had to drop the pan after I put the engine back in because I used the wrong pan seal. I was able to do it easily though. My truck is a 63, so I'm not sure if there is much difference between the cross members.
I did not remove the starter. All I had to do was drop the exhaust and rotate the engine to where the counterweight of the crank was up in the block at the front of the engine
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
