Old 09-08-2018, 07:13 PM   #1
gmc1971harwich
gmc1971harwich's Avatar
72 jimmy 350 sm465 oil leak
I have a 72 jimmy has a 350 sm465 4 speed and it’s leaking oil somewhere underneath up inside of the bellhousing. The throwout bearing is caked with oil and I’m getting bad clutch chatter on takeoff. Any idea Where the leak is originating from these pics?
gmc1971harwich is offline   Reply With Quote
Old 09-08-2018, 07:21 PM   #2
gmc1971harwich
Re: 72 jimmy 350 sm465 oil leak
This is my daily driver😁
Old 09-08-2018, 07:36 PM   #3
gmc1971harwich
It look like the whole outside of the bellhousing is covered in oil also
Old 09-08-2018, 09:09 PM   #4
simicrintz
I don't know (sorry) but are you running it open like that (without the inspection cover?)?
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 09-09-2018, 08:36 AM   #5
gmc1971harwich
bought the truck with no cover haven’t found one yet has a hydraulic clutch anybody know where I can get one?
Old 09-09-2018, 08:37 AM   #6
gmc1971harwich
I was thinking it might better to not put a cover on until I get the leak fixed so the oil has a place to go instead filling up in the inspection cover
Old 09-09-2018, 11:08 AM   #7
simicrintz
I have rationalized many things like that through the years as well To me that is just a place for all kinds of stuff to enter and cause problems if left open.
-Bruce
1971 K5 Blazer 4WD
Old 09-09-2018, 12:16 PM   #8
gmc1971harwich
I’ve had a hard time finding an inspection cover for it as I said when I bought the truck it didn’t have one if anyone knows of where I can find one let me know 👍
Old 09-09-2018, 10:06 PM   #9
72k5ls
Are you losing engine oil or gear oil if from the transmission I would say the input shaft seal on the transmission which would explain the oil getting into your clutch. Better pull the fill plug on the transmission to check your oil level should be even with the threads on the fill plug.
72k5ls is offline   Reply With Quote
