09-08-2018, 07:19 PM | #1 |
Brake line question - need some input
First I searched & read quite a few threads on this but none addressed my specific question, so here goes:
Working on a 65 c10 & in the process of installing disc brakes. PO did very little right on this truck. He did replace the brakes & lines but not sure he used the correct size for the rear line. I have read several posts that say 3/16" for front lines, and 1/4" for rear line up to the T fitting. Have also read that some noted pre 66 trucks had 3/16" for the long rear line. So 1st question is the existing rear 3/16" ok to use? 2nd question deals with the disc brake kit I'm installing. It came with braided steel front hose lines that take a 1/4" line connection. Should I use 1/4" lines in the front or get an adapter for the hoses to run front 3/16" lines? Any info or suggestions is much appreciated. Thanks guys.
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon Last edited by ScottH; 09-09-2018 at 09:33 AM. |
09-08-2018, 07:56 PM | #2 |
Re: Brake line question - need some input
Scott i have 1/4" lines to all my brakes on my 66. Every thing in the front is 73 to 87. Works fine. I used a line from the rear to the frame that was also 1/4 on the frame end and it is 3/16 to the rear wheel cylinders.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-09-2018, 09:31 AM | #3 |
Thanks 4 the info Jimmy.
Anyone else?
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
09-09-2018, 03:28 PM | #4 |
I Just made new stainless lines for my truck last weekend. I have 4 wheel disk brakes and I used 3/16" line from master cylinder out to all 4 brakes. I would keep everything 3/16" same as the rear already is. There is a lot of info on the internet from pretty smart people that know hydraulic's and Pascal's Principle, line sizes and so forth.
