Old 09-09-2018, 03:56 PM   #1
KQQL IT
At the body shop.
KQQL IT's Avatar
POA eliminator or poa with a sanden compressor
Looking at getting the A/C going in old blue with a sanden A6 replacement.
And in the also bought list was a POA eliminator.
Is it worth buying and swapping to cycling system?
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 09-09-2018, 05:43 PM   #2
dmjlambert
dmjlambert's Avatar
Re: POA eliminator or poa with a sanden compressor
Does this mean you bought a compressor and a POA eliminator? I didn't understand the part about "in the also bought list."
dmjlambert is offline   Reply With Quote
Old 09-09-2018, 06:45 PM   #3
Custom 68
Custom 68's Avatar
I have the cycling eliminator it works OK but I wish I had my poa back in place.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-09-2018, 06:50 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
When I clicked on the sanden-A-6 compressor.
The other recommended items was an o-ring kit and the eliminator and a few other items
Old 09-09-2018, 06:55 PM   #5
dmjlambert
dmjlambert's Avatar
So when the compressor clicks on, there is some sort of problem and the recommended fix for that is some o-rings and eliminator? Sorry I will just bow out of the discussion and see what others say. I could probably learn from this.
Old 09-09-2018, 08:16 PM   #6
Red71gmc
Hahaha. I think what he means is when he was ordering the compressor online, and clicked to order it, the site recommended other items to go along with the purchase of the compressor.
I am in no way making fun of you but rather seeing the humor in two different ways to read a post. It happens to me in reading text messages. I miss the voice conversation days for this reason.
Red71gmc is offline   Reply With Quote
Old 09-09-2018, 08:21 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Ha, Thanks for translating.
Old 09-09-2018, 08:29 PM   #8
dmjlambert
dmjlambert's Avatar
Oh, OK, I get it now, I'm just a little dense today. :-)
Old 09-10-2018, 08:49 AM   #9
clay68c10
clay68c10's Avatar
Keep your POA, just adjust it to the correct pressure for 134 if you're using that refrigerant. Cycling clutch won't cool as well, especially with 134.
If you can swing it, update the condenser to a parallel flow with 134.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
