Rear Axle codes?
I did a few google searches and nothing came up.
Is there any where I could go to identified the gears in the rear end? The axle code starts with KAD and is out of a 74 2wd C10. Did the 73-74 12 bolts come with the posi option? |
#2 | |
Moderator
![]() Join Date: Oct 2008
Re: Rear Axle codes?
1974 KAD was a C10 axle equipped with a locking diff and 3.07 gears. You can see that some of the 73 P & G series Vans had positraction. so... GM differentiated between the locker and posi. I don't believe the 73-91 CK trucks got Positrac. Don't use limited slip additive in this axle if it has the original Eaton Locker. http://gmpartswiki.com/getpage?pageid=60427
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
After 44 - ish years there's really no telling what's in there.
Best bet is to pull the cover and count teeth and replace the gear lube while you are at it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
