how low can you go without a c notch or air bags??
I prefer the lowered look but not slammed on the ground so I was wondering how low can I go? Which kits are best and maybe some pics of your lowered truck?I think I would like a 20" wheel such a riddler or US Mag.
Re: how low can you go without a c notch or air bags??
Mines on airlift bags. Not notched with 20" rear and 19"front. Camaro axle and s10 frone discs with drop spindles..can drive it that low as the headers are on the deck.
I am 5 inches lowered on the rear and I did add the notch. I am not sure you can comfortably get by without a notch at that level but I am sure some have. Personally I would be cautious at 5 or above if you are going to carry anything.
I am on 18 inch wheels. Static spring drop.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
No c notch. 6.25 rear. 4.5 front. No problems.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
My static drop is ECE 4.5/6 without any problems. ECE parts are good. I'd call and chat with the guys at ECE, they are knowledgeable and helpful.
Jon |
X2 on ECE. I have their 4/6 drop kit and am not using a c-notch. No problems to date. Sway bars will be a great addition as well.
72 C10 lwb fleetside -stock 350/350 combo |
https://www.youtube.com/watch?v=3_uDA4t29QA
i love this color combo,rims and stance,I would love a swb though |
ECE on the front of mine with 2 1/2" spindle and 2" springs. DJM flip in the rear which netted just over 7". No notch.
are you guys still able to run the inner fender wells up front ?
I don't think we're close to having that problem with a 4.5" drop in the front. Maybe if you're running 22's.
Except for the drop and the wheels my truck is all stock and all complete. 27” overall height front tire and 29” rear with no rubbing. The stepside requires careful backspacing of the wheels depending on the axle housing used to get big tires to fit but that’s about it on a 4.5”/7”.
#13 |
I'm curious on how you guys are lowering that much without a notch. I know my frame has been shortened etc but I have 6" of gap between tire and fender lip and only 4" between top of axel and frame. So I'd have to notch just to get rid of wheel well gap...
'67 C-10 SWB '18 Sierra Denali '18 Volvo XC90 |
#14 |
| Bookmarks |
