Old 09-09-2018, 11:15 PM   #1
85raiderburban
85raiderburban's Avatar
'95 suburban gas gauge pinged at E
Tested the gauge and its working. Checked the sender GND (-) and its good. Would it be the purple sender wire grounded somewhere between the gauge and the sender itself?
*UNDER CONSTRUCTION*
'80 Suburban C20 (C6P) (Silverado)
- '68 472 (Edelbrock 1813, PH8026 LT's, H pipe) / '91 4L80 (manual shift,vac modulator, 350 converter) / 14B FF 3.21 G80 34' s/ '96 GMT400 interior
85raiderburban is offline   Reply With Quote
Old 09-10-2018, 04:31 PM   #2
mikebte
Re: '95 suburban gas gauge pinged at E
If you ground the purple wire to frame does the gauge move?
If my memory serves correct, around the steering shaft is a connector that will allow you to test the wires. The fuel pump power, gauge and ground all run threw this 4 or 3 pin connector. Good place to ohm out the wire and test for power.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
Old 09-10-2018, 08:49 PM   #3
85raiderburban
Yes, grounding the purple sender wire makes the needle move, thats how i tested it. Forgot to mention, this is carb converted. No electric fuel pump on the sending unit since I replaced it with '6 fuel line to the bottom of the tank. fuel pump GND and 12v wires were eliminated also.
Old 09-10-2018, 08:58 PM   #4
speedygonzales
speedygonzales's Avatar
If you change the situation and get a different result...
OK if you short the signal wire to ground and it moves in the opposite direction, doesn't that tell you something?
Like the signal wire is open. (infinite resistance)?
Or am I missing something here?
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 09-10-2018, 09:51 PM   #5
mikebte
Sounds to me like a bad sending unit. Sending unit should have residence, you can check it to ground, my money is no bad sending unit being as the fuel level sender is built into the sending unit.
My YouTube:
