Old 09-09-2018, 11:18 PM   #1
WyattTX
Power steering fluid loss.
On my my '85 C10 Sliverado with a replacement 350 SBC engine, my power steering fluid is going somewhere. Removed my power steering pump, inspected it, and found no evidence of leaks. I also replaced both hoses. However, I am still losing fluid at a rapid rate. I have even popped the hood open, and watched the all the components, while a friend turned the wheel, and found nothing. The only thing I can think of, is the steering gear box. But I see no evidence of it leaking. Does anyone have an idea, what could be happening? Thanks.
PS: I know it has been a while since i have posted here, but I will try to be a little more regular. I cant believe how much time has passed.
WyattTX is offline   Reply With Quote
Old 09-09-2018, 11:32 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Power steering fluid loss.
My blazer was losing fluid bad...it was the output side of the gearbox seal...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-10-2018, 09:55 AM   #3
andyh1956
Run down to AZ & pick up a cheap UV test kit. Glasses, Light & Dye.
You'll be able to find it then.
That stuff works so good you can find the money missing from your wife's checking account!
andyh1956 is offline   Reply With Quote
Old 09-10-2018, 10:43 AM   #4
WyattTX
Thanks, I will investigate this further. I will post, if I fix it.
