Old 09-09-2018, 11:43 PM   #1
Chris 71 K10
Chris 71 K10's Avatar
71 K10 front drive shaft remove and install help
So I recently got this 1971 K10 from a friend who had it for years but did not really use it much and didn't have much history on it. The front drive shaft is in need of replacing and there are plenty of places to get rebuilt ones with a core swap. It looks like a pretty simple job. I may cuss the 4 bolts on the transfer case side of the shaft as I can't really see them but I can feel them enough to get to them. That part might be a slow process that I won't love but, is it really a simple as I think it may be or is there anything or special tool that may help? It seems like the 4 bolts on the rear of the double cardan and the 4 nuts on the front by the U Joint, then collapse it a little and it should drop right out. Does this sound right or am I missing anything before I get into it?
The pickup has a 350 motor, NP205 transfer case, TH350 trans if I understand everything correctly.
Chris 71 K10 is offline   Reply With Quote
Old 09-09-2018, 11:55 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: 71 K10 front drive shaft remove and install help
Yep just about that easy. Nice looking truck you’ve got there!
Tyler
57taskforce is offline   Reply With Quote
Old 09-10-2018, 07:16 AM   #3
Bigdav160
Bigdav160's Avatar
Take the differential joint out first and straighten the shaft. The CV joint has fine threads and an angle on the joint is hard on the threads.
PS don't worry if you can't get the bolts completely out because of interference with the transfer case.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-10-2018, 07:43 AM   #4
jjzepplin
jjzepplin's Avatar
I put the t case in "N" and unlock one hub and lock the other. I undo the one bolt that has the most clearance. 1/4" 12 point bolt if I remember. It takes a bit of time and I cramp up a bit... HAHA but then I unlock the hub and turn the shaft to reveal another bolt and lock the hub etc. I kick myself sometimes for not installing a later style flange that has nuts and bolts. Mostly because I had one and sold the t case it was on. FACEPALM! My rear flange is from a FURD one ton and has big bolts and a double cardan from Tom Woods. Nice unit.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-10-2018, 10:23 AM   #5
jaros44sr
jaros44sr's Avatar
I had luck taking the trans cover off and out from interior, made it alot easier to access the rear bolts at the transfer case
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-10-2018, 10:55 AM   #6
Chris 71 K10
Thanks guys, always a helpful board with good tips and feedback.
Old 09-10-2018, 10:57 AM   #7
Travisarmenta
Travisarmenta's Avatar
Amazing truck. Post more pics so we can all enjoy.
Travisarmenta is offline   Reply With Quote
