Old 09-10-2018, 10:34 AM   #1
Custom 68
Custom 68's Avatar
6 lug spare tire suggestions
Hello all, I am curious on what a spare tire recommendation might be for my 6 lug truck. I have the underbed gas tank so I will need to carry this in the bed. I don't think they make a "donut" spare that I can find anyway. I have one of my original wheels that is 15 inch I need to see if it will clear my front brakes but was hoping for something a little lighter.
Thanks,
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-10-2018, 11:20 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: 6 lug spare tire suggestions
No spare at all. Use triple A premier membership and leave the spare at home . But if you have decent insurance you should have free road service and towing already ?
https://autoclubsouth.aaa.com/Member...m_page=AAA.COM
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 09-10-2018, 04:43 PM   #3
72timemachine
If you are concerned about space in your bed, my '72 c10 super has a factory bracket which is mounted in the front driver's side corner of the bed so the tire stands upright. The bracket uses the bed bolts along the bottom but uses other ones to hold the bracket to the top of the bed rail. It then uses a rod which passed through the center of the bracket in order to secure the tire in the upright position. You could make a pass through rod which accepts a lock so no one steals your tire. Where I roll, you need to lock everything as classic trucks are a target in my hood. Keep a spare with you case cell phone reception is not a given as you never know where you will get a flat. Personally, I'm a flat magnet.
https://www.google.com/search?q=1972...KR71iXz0ye4pM:
72timemachine is offline   Reply With Quote
Old 09-10-2018, 05:20 PM   #4
Custom 68
Custom 68's Avatar
Ha Grumpy that is what I had been doing. I threw one in for a bit and then took it out. I did have triple A but didn't keep it up.
I have a flat topper so a stand-up tire is out but I have seen those they do work great. I was really looking for something lighter and bigger than my 15 inch but I didnt know what it might be.
I think I am all good, I will be heading to crusin the coast in about 3 weeks or so and was going down my mental check list.
Thanks guys
Dave
Dave
Old 09-11-2018, 05:57 PM   #5
Vero67
Here is mine
Vero67 is offline   Reply With Quote
Old 09-12-2018, 09:56 AM   #6
Custom 68
Custom 68's Avatar
Vero67 thanks for the picture that looks good in there.
Dave
Dave
Old 09-12-2018, 10:00 AM   #7
Vero67
Thank you, I also moved my gas tank to under the bed. I used the filler neck setup from a 70 Blazer. I like the look and no slow filling problems. Plus I don't think a 35" tire would fit under the bed.
Old 09-12-2018, 02:16 PM   #8
67chevemall
67chevemall's Avatar
Originally Posted by Vero67 View Post
Here is mine
Looking good.
Painted my holder last night. Off to find 8" carriage bolt and get to installing it.....
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
