Drum proportion valve
Doing a disc conversion with an Astro van booster on a 70 C20. Question is can I used my old drum/drum proportion valve or switch over to a disc/drum one. Previous owner ran new brake lines and was seeing if I could keep them. Thanks
Re: Drum proportion valve
Technically the drum block is a distribution block and not a proportioning block aka Combination Valve. You need a combination valve for the disc brake setup.
I snag a proportion valve off an old g van since they seem to go unmolested in pick n pull yards.
Moderator
![]() Join Date: Jun 2017
What master cylinder do you intend to use?
Suggest you get a true disk / drum style master as drum/drum has line valves in the ports to keep a small amount of line pressure in lines to keep rubber cups out against wheel cylinder bodies... Disk calipers can bind up if the valves are not removed from drum / drum masters... Much better to use disk/drum system and correct proportioning valve... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
#5 | |
Who Changed This?
![]() Join Date: Jan 2013
I have a new MC for a 73+ 3/4. My setup looks like this. I thought the Astro van booster was what a lot of folks was running?
Hydroboost from an Astro is fine.
I have one installed on my Suburban
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
