Old 09-11-2018, 09:00 PM   #1
rickywideglide
rickywideglide's Avatar
parking brake cable clamp 1964 lwb
been awhile since ive posted on here,still the best place for info and help .with that said ive searched everywhere for a clamp that holds parking brake cable to trailing arm, I don't believe its the L shaped bracket,more like a heavy duty p-clamp,any help greatly appreciated .
rickywideglide is offline   Reply With Quote
Old 09-12-2018, 09:11 AM   #2
LT1 Burb
LT1 Burb's Avatar
Re: parking brake cable clamp 1964 lwb
They are pretty tough to find because they are stamped around the ebrake cable and are a ***** to get off, you may have to hit a wreckers.
LT1 Burb is offline   Reply With Quote
Old 09-12-2018, 09:14 AM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Are they not the same clamp used at the steering column to hold down the forward cable? Sure look similar.
Old 09-13-2018, 07:44 AM   #4
rickywideglide
thanks for replies,i checked the one at front cable ,it has a locating tab on it that holds it in place so it might work...
Old 09-13-2018, 05:36 PM   #5
aerotruk63
aerotruk63's Avatar
Please let me know if the clamp is the same or close too.
Old 09-13-2018, 09:04 PM   #6
rickywideglide
Size:  95.3 KB heres a pic of front clamp under steering column,i think it would work with a hole drilled in trailing arm,theres only one hole now,what im using now moves so outer cable moves when parking brake applied,so brake isn't applied as good as it should be ,probably could use a later style bracket as well
