Old 09-13-2018, 11:05 AM   #1
andrewpclayton
andrewpclayton's Avatar
clutch pedal removal for automatic conversion
My plan is to cut it off with an angle grinder... is there a better or more efficient or faster way?
1977 SWB (c20 conversion) SBC350
Springfield Oregon
Instagram: @nevernotchevy
andrewpclayton is offline   Reply With Quote
Old 09-13-2018, 11:13 AM   #2
andrewpclayton
Re: clutch pedal removal for automatic conversion
I guess nothing would be faster than cutting it off lol
Springfield Oregon
Old 09-13-2018, 11:48 AM   #3
adricar1
it unbolts and pulls out, if you look at the pedal box you wll see what needs doing.
GMC K1500 1971 350 cu in th350 4wd
Bondo Bob c 10 1971 stepside th 350
c10 1970 350 cu in manual air con stepside.
adricar1 is offline   Reply With Quote
Old 09-13-2018, 11:54 AM   #4
demian5
demian5's Avatar
Post it up for trade for an auto pedal assembly instead of hacking it up. Someone needs one!
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 09-13-2018, 01:45 PM   #5
andrewpclayton
Interesting idea.. I will see how cleanly I can get it out this weekend
Springfield Oregon
Old 09-13-2018, 07:09 PM   #6
cleszkie
cleszkie's Avatar
It will be 1000% easier to remove the clutch pedal from the assembly if you remove the whole pedal assembly from the truck first. Otherwise, you will be working upside down, in the dark, with you back twisted 180 degrees and bent at a right angle. You won't be right for a week afterwards.
cleszkie is offline   Reply With Quote
Old 09-14-2018, 01:58 AM   #7
Rob#2
please don't cut it, I want to convert my 72 to a manual, can I have your clutch pedal?
Rob#2 is offline   Reply With Quote
Old 09-14-2018, 02:32 AM   #8
OregonNed
OregonNed's Avatar
Mine was taken right out, and later I installed a wider pad from Lokar that was a nice improvement...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
