Letrs see your aftermarket steering wheels
Looking for something cool to match a woodgrain interior 72 c10
Re: Letrs see your aftermarket steering wheels
My experience w/ aftermarket wheels is crap. I'd get (and have) a stock wheel from a GM vehicle and wrap it in leather (wheelskins.com). If I do it again, I'll get some inner tube or something and put a layer or two on the wheel first to make it fatter and softer like a modern one.
Wheelskins took my measurements and made a new skin for my 4-spoke Camaro wheel. $10 for the wheel and $30 for the skin seemed cheap at the time. I think I sold the aftermarket wheel for about the same amount. Another nice thing is the horn works. The red one in the link is similar to my Camaro wheel. https://www.google.com/search?q=4+sp..._9pwV8sa3jXaM: That wheel is on a Camaro. I have a black stockwheel stached for the truck. There are 80s 4-spoke truck wheels like the one currently on my truck that don't look bad. https://www.google.com/search?q=4+sp...-PbpPUfjzZ3bM: |
the grant 1175 collectors edition isn't bad
I installed a 60's corvette wheel in mine. It had a tan lecarra when I bought it, but way nicer now. Uses a camaro hub.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
While aftermarket steering wheels can work, they tend to be an expensive "cheap" PITA and you never know when the horn's gonna throw sparks. Definitely look into putting a different Chevy wheel in there if you can not live with the originals.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I have this one on my truck. Its a Le Carra and I like it and have been using it since 2006 on two different trucks.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Really like it, but I have to figure out where I bought it...
1970 C10 Short Stepper with 71/72 front clip. |
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
Am still looking for one with less "dish".... I'm told a '69 Camaro wood wheel will work, but am skeptical regarding mounting to column. Maybe...
I have this wheel in my truck, but it’s the black foam grip version. The horn button works fine, and it looks good i there.
Forever Sharp?
71 Cheyenne LWB - RideTech Air, zz502, 20" Torq Thrusts 16 Sierra - Bilstein 6112/5160, 33" Duratracs, Method Race Wheels, GMPP Intake, Borla Exhaust 15 4Runner - Icon Coilovers, 33" Duratracs, Pro Comp Wheels, NFABs 16 Malibu Response TXi |
#13 |
I went from this pilot to a GM comfort wheel . The mount on the pilot moved the wheel to close to my chest. Horn didn't work. New one from Ausley's chevelle was 209$ Complete. Works perfectly. The new wheel has a larger diam than the pilot just the way the picture was taken it looks smaller.
#14 |
I got one off a 1976 or 77 pickup with the wood grain strip in it. When I bought my truck it had one of those little tiny wheels in it. I like the wood grain because it goes with the wood grain on the dash.
#15 |
I redone the wood on this one.
#16 |
I spent 350 bucks on a supposedly rosewood steering wheel from one of the main vendors so thought it would at least be wood and all it turned out to be was a plastic POS that’s supposed to resemble wood. Fair to say I was not impressed anyone else run into that issue?
#17 |
The GM "Rosewood" wheel was plastic as well so that would be correct for a reproduction. Same with Walnut. The only real wood wheel from GM was the optional N32 Teak steering wheel from 65-66 Corvette.
I also run the GM Comfort Grip wheel in my '69 short step, in my 69 Camaro, and in my '79 CJ5. I ditched all the aftermarket wheels. I did buy a Grant that is styled after the Comfort grip wheel that uses the GM hub from the Comfort Grip wheel but haven't installed it yet. My Jimmy has an 88-94 GMC truck wheel which can be a good junkyard choice. To mount the repro Rosewood, Walnut, or Comfort Grip wheel in a 67-72 truck use a 67-68 Camaro hub kit. Or from any GM passenger car that had the ignition switch on the dash like '68 Chevy II (Nova) or a 65-68 Chevelle depending on who your favorite vendor is. Here is an aftermarket wheel that uses the GM hub and they claim is real walnut for less than $200 which seems a deal. I think it would work with the Camaro hub but I'm not sure. I thought they all used the same pattern but the questions below that wheel put some doubt in me.... (edit: Link below to wheel hubs and why 63-66 Corvette is different) https://www.corvettemods.com/C3-Corv...SABEgJJw_D_BwE http://www.camaros.org/swheel.shtml#misc more on steering wheels: http://www.camaros.org/swheel.shtml
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 09-16-2018 at 08:54 AM. |
#18 |
Well there you go you learn something new all the time. I was pretty disappointed when I pulled it out of the box but you get that. I think I’ll end up with the plain black comfort grip version. Thanks for clearing that up I really thought I had gotten the shaft haha
#19 |
My 66 SS Chevelle has the two spoke "rosewood" wheel its oem but its plastic.
#20 |
![]() Join Date: Dec 2012
This is the second of two Forever Sharp 14" wheels I have used. I can add a wood half wrap if desired..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#21 |
Forever Sharp with custom color matched vinyl wrap.
