Old 09-15-2018, 03:49 PM   #1
Big Blue
Big Blue's Avatar
watzit called
What is the "nut" that goes to the front break hoses next to the frame called. This is the one that you have to remove in order to get the hose out.
Any questions please ask, I may not have explained it well enough.
John
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
Old 09-15-2018, 04:37 PM   #2
Rickysnickers
Rickysnickers's Avatar
Re: watzit called
Are you referring to this part? https://shop.advanceautoparts.com/p/...FYzfWwodLOEP-w
Old 09-15-2018, 05:56 PM   #3
Bloodhound
Re: watzit called
Do you mean this?
Bloodhound is offline   Reply With Quote
Old 09-16-2018, 12:47 AM   #4
Big Blue
Big Blue's Avatar
Re: watzit called
Bloodhound, yes that is it. What is it called, not just a " NUT" IS IT?
and Rickysnickers, I think that is used for the rear set up, now that you show that, I think I may need that for the rear.
John
Big Blue ( John )
Old 09-16-2018, 11:46 AM   #5
Bloodhound
Re: watzit called
John
I think it's just a jam nut.
Old 09-16-2018, 09:02 PM   #6
Misled
Misled's Avatar
Re: watzit called
I had the same question!
Here ya go.......
http://67-72chevytrucks.com/vboard/s...&highlight=nut
Misled is offline   Reply With Quote
Old 09-17-2018, 01:16 AM   #7
Big Blue
Big Blue's Avatar
Re: watzit called
Thanks everyone for responding. I think it is safe to say that it is called a " JAM NUT ". I may need just one. Thanks Again, John
Big Blue ( John )
