Old 09-15-2018, 06:00 PM   #1
justjoef
Starting issue after fuel tank and lines installed
New tank and lines (lines new from bell housing connection and lower). Never touched the lines going into the Central SFI. Depressing the schrader valve on the feed line shows fuel up to that point (beyond any repaired lines, etc.) Yet the truck won't start. It started and ran fine prior to this repair. Now ... nothing. I had four plug wires off at the distributor (they were blocking access to the fuel line connections), but I numbered them before removal and have since verified the firing order is correct. Any ideas folks? I'd appreciate any feedback. Thanks.
'97 GMC Sierra K2500 SLE XC 5.7L
justjoef is offline   Reply With Quote
Old 09-15-2018, 06:28 PM   #2
SACRAMENTO 71
SACRAMENTO 71's Avatar
Re: Starting issue after fuel tank and lines installed
Turn over? Hear fuel pump prime with key on?
68 C10 SWB W/ 72 FRONT CLIP 343SB TH400
64 C10 SWB 406SB TH400
74 SUBURBAN 454BB TH400
78 K10 SWB 350 TH350 6" ON 35" BFG MUD
71 K5 350 W/ TBI 700R4 6" ON 38" BFG MUD
00 K3500 DRW BIG BLOCK "DRINKING PRBLM"
SACRAMENTO 71 is offline   Reply With Quote
Old 09-15-2018, 07:46 PM   #3
justjoef
Turns over fine. You can hear the fuel pump prime with the key on. The feed line is pressurized. I cracked it at the fuel filter before I tried the schrader valve. It's getting fuel (at least up to the schrader valve).
Old 09-15-2018, 09:49 PM   #4
Stormin08
Stormin08's Avatar
Try cracking the fitting, possible air trap against the injector ?
Possibly knocked the ignition wire into the distributor loose ?
Verify spark.
Stormin08 is offline   Reply With Quote
Old 09-16-2018, 12:41 AM   #5
speedygonzales
speedygonzales's Avatar
What's the pressure
Measure the fuel pressure with KOEO. If you don't have a pressure gauge and don't want to buy one, you can borough one free at O'Reilly's.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 09-16-2018, 12:46 AM   #6
franken
Duh. Get some B12 and shoot it into the intake. Crank. If it fires, it's a fuel problem. Then measure things.
Asking the internet for nonsense answers is not troubleshooting. Thinking is a better approach.
franken is offline   Reply With Quote
Old 09-16-2018, 02:19 PM   #7
justjoef
Some of us are more knowledgeable than others with these things. Thanks to those who took the time to offer constructive advice and possibilities to check. I appreciate the input.
Old 09-16-2018, 02:32 PM   #8
Stormin08
Stormin08's Avatar
I am leaning toward lack of spark...possibly even a grounded power wire.
Old 09-26-2018, 08:41 AM   #9
speedygonzales
Well ?
Pride and joy
