09-15-2018, 08:06 PM | #1 |
suburban door jamb
Any chance someone has a picture of what this area is supposed to look like? I've been working on getting the rocker and the front quarter panel to fit and realized that this area needs some work as well. This is the left side rear door panel area.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
09-17-2018, 08:17 PM | #2 |
Re: suburban door jamb
I made a couple pieces and welded it up tonight. Next problem... rocker to quarter panel fit.
Has anyone else run into this? The profile of the rocker and the quarter don't match! There is a flat spot on the bottom of each piece. The replacement quarter has a much larger flat spot than the rocker.
09-17-2018, 09:21 PM | #3 | |
The Older Generation
Is the rear quarter up against the "B" pillar all the way or is there a gap in it at the bottom. When I did my panel truck I used a door skin and the lower part of a rocker panel welded together and everything lined up OK. I know, not really a good comparison but should be close. LockDoc
09-18-2018, 12:02 PM | #4 |
I think that is considered normal and from the factory they were mounted the same way. At least I've read that in the body work section.
It was noted that body guys usually make some adjustment to flush that out at the customers request. Here's how mine turned out. Sorry I didn't take any pics before the patch panels were installed.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
09-18-2018, 03:01 PM | #5 | |
Thanks Dave and Leon. I'm thinking of adding to the inner rockers bottom edge to bring the outer rocker out further. It only needs to come out less than a quarter inch for the rocker and quarter to line up. My OCD will never allow me to leave the two pieces un aligned! Pau
09-18-2018, 06:48 PM | #6 |
Can you tweet the inner rocker out bit for the rocker and in for the quarter panel? Just be careful what ever you do moving the rocker out, so as not to make the rocker sit out further than the fender. You might want to hang the door and see which one it lines up with.
09-18-2018, 07:38 PM | #7 | |
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
09-19-2018, 08:36 PM | #8 | |
Paul
10-04-2018, 08:00 PM | #9 | |
Thanks Paul
10-05-2018, 09:10 AM | #10 |
No, I installed the quarter first. I've been told to work from the rear of the vehicle to the front. I then installed the rocker. It's funny how the passenger side sits almost flush but the drives side the quarter is slightly more proud.
I used Eastwood "brush on" seam sealer from a can. Troweled it on with a bondo spreader and cleaned it off with alcohol before it dried. And it dried fast. On the floors of my Z-28 I used 3m two part "self leveling" seam sealer. I found it much less viscous and harder to work. It does a good job but if the gaps are not tight it tends to just drip through. I don't think it would work for the gap between the quarter and rocker.
10-05-2018, 11:18 AM | #11 |
Thanks Dave. Just reread my post. We are both doing it the same way. Looks like my wording is confusing. Quarter first then the rocker. Have to see what seam sealer I have in the cabinet.
Thanks again! Paul.
10-05-2018, 12:18 PM | #12 |
Post Whore
It sounds like you are the owner of a Monday or Friday truck like me. I didn't replace the rockers on mine but during the body work phase I noticed how my passenger side rocker fit well at the back but at the front the bottom is pulled in about 3/16" and there wasn't any way to get the fender to line up. Part of the reason I'm sure I have a Monday or a Friday truck. I thought about cutting it apart but decided to wait as the rockers are still pretty good, but the demon never sleeps so the day will come when it will have to get fixed.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
