Old 09-16-2018, 10:11 PM   #1
Hammond68
Wiped a lobe.
My cam is shot. All stock 1972 c10 350 as far as I know. I haven't torn it down yet. I'm looking at the 2102 edelbrock performer plus cam kit.
Anyone else use this? Is it compatible with the stock heads-springs? Thanks in advance for any advice.
Hammond68 is offline   Reply With Quote
Old 09-16-2018, 10:25 PM   #2
CUDA8U
CUDA8U's Avatar
Re: Wiped a lobe.
a friend builds a lot of sbc and useless the mother thumper,he has been averaging 510-549hp
CUDA8U is offline   Reply With Quote
Old 09-16-2018, 10:37 PM   #3
jessemthompson
Re: Wiped a lobe.
This cam works well with stock heads. It’s been a very long time ago, but I ran this cam In A 350 with an edelbrock intake and stock springs. It ran well with good low end torque.
jessemthompson is offline   Reply With Quote
Old 09-16-2018, 11:03 PM   #4
geezer#99
geezer#99's Avatar
Re: Wiped a lobe.
If you wiped a cam, don’t waste your money on any new cam.
You need to tear it down and hot tank it and replace all the bearings.
All that fine cam lobe metal is now all through your motor.
Or flip a coin, take a chance, put the new kit in, spend a grand, enjoy it awhile until it all comes grinding to a halt again.
JMHO
Old 09-16-2018, 11:12 PM   #5
weq92f
weq92f's Avatar
Re: Wiped a lobe.
Yeah, agree, if you wiped a lobe, that material went down into your oil system as very fine particles over the time it took to wipe the lobe. Doesn't really matter how long it took, it's those particles embedding into the bearings and being inside every nook of your oiling system that is worrisome. Imagine fine metal shavings in your oil!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 09-16-2018, 11:26 PM   #6
weq92f
weq92f's Avatar
Re: Wiped a lobe.
If you have the cam card, it should reflect the required spring specifications.
Some quick poking around reveals this information...
NSTALLATION NOTES:
Do not use late model timing sets. They are machined in a retarded position and are not recommended for this camshaft installation. Use Performer-Link Timing Chain Gear Set 350-7800 or similar set.
Use only stock or Edelbrock Springs 350-5802 or 350-5902 (for rotators).
Use only with stock 1.5 rocker arm ratio
50-State Legal E.O #D-215-19
.... from this site....
https://www.jegs.com/i/Edelbrock/350...SAAEgLLrvD_BwE
Hth,
-klb
Old 09-17-2018, 07:42 AM   #7
jessemthompson
Re: Wiped a lobe.
JMHO
He’s got another post where he states he’s doing a full rebuild.
Old 09-17-2018, 03:54 PM   #8
cleszkie
cleszkie's Avatar
Re: Wiped a lobe.
For the effort of a full rebuild I would just get a roller block and be done with wiped lobes. Be miles ahead of the performance game too with just some stock vortec heads and intake.
cleszkie is offline   Reply With Quote
Old 09-17-2018, 05:41 PM   #9
truckster
truckster's Avatar
Re: Wiped a lobe.
I agree. Get yourself an L31 crate motor and get Vortec heads, a roller cam, 1-piece rear main seal, and a 1-piece pan gasket. You'll need an intake, mellonized distributor gear, and an electric fuel pump, but you'll probably still save money and have a much better engine.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is online now   Reply With Quote
Old 09-17-2018, 06:01 PM   #10
Hammond68
Re: Wiped a lobe.
Thanks for all the replies.
To Jesse. I'm not doing a full rebuild yet. You must have mistaken someone else's post as mine.
To CUDA8U. This is a daily driver. I can't go all out and build 500hp toy.
To weq and geezer. I definitely see your point on that lobe went somewhere.lol. Cams have been changed out after wiping lobes without encountering new problems. I do understand its iffy though. The cam is 168 plus the cost of gaskets so it wouldn't be a grand. Doing the swap myself of course.
I've thought about new engines,383ht,building a 383.going with a 400sb,Rebuilding my 350. After all the thought and research I've even though of just a stock rebuild and be done with it. It's an overwhelming task deciding what to do. I've already got a 700r4 tranny installed. I haven't taken the pan off the rear end yet but will wind up with 373s one way or another.
This is a daily driver. I'd love 25 mpg but I know that won't happen. I'd love a 454 but don't want 6-8 mpg either. It's hard to find a happy medium. I'm looking for a good efficient engine to build and opinions are definitely wanted. I'll be driving this truck all over the nation as I already have.
Old 09-17-2018, 06:06 PM   #11
4carbcorvair
Re: Wiped a lobe.
I lost a lobe on a Corvair engine. I completely tore the engine down, found metal particles all thru the engine/oil passages.
68 K20 Custom Camper/CST Wrecker.
97 GMC K1500 short bed reg cab.
4carbcorvair is offline   Reply With Quote
Old 09-17-2018, 06:43 PM   #12
Hammond68
Re: Wiped a lobe.
Thanks truckster and cleszkie. L31 looks decent. Will it run on 87 octane being 9.4 to 1 compression. 91 or 93 wouldn't kill me though. Also will all my brackets such as ac,starter,alternator ect bolt on or would that turn into a headache?
Is anyone running this engine? If so what's the milage like? 700r4, 255 70 15 inch tires with 373? Gears here.
Old 09-17-2018, 08:11 PM   #13
jessemthompson
Re: Wiped a lobe.
I definitely did mix you up with someone else who just wiped a cam lobe. My apologies.
Old 09-17-2018, 08:59 PM   #14
garyd1961
Re: Wiped a lobe.
Great advice^.
garyd1961 is offline   Reply With Quote
Old 09-17-2018, 09:14 PM   #15
garyd1961
Re: Wiped a lobe.
I have been running one a couple years now. It's not a daily driver but I drive it every weekend when ever I get a chance during the week. All your brackets will work but you need a vortec intake Summit has them for around $150. You also need a melonized distributor gear, electric fuel pump(which almost killed the deal for me, glad it didn't). You also need a flexplate for a one piece rear main seal.
I don't know the exact gas mileage I'm getting but I can tell you it's way better than my old motor. I estimate it to be between 15 and 20 mpg if I drive it right but that never happens ,lol.
There was a post on here the other day where someone found the L31 crate motor for around $1700 or close to that. I paid $2000 and I'm happy with mine.
Old 09-17-2018, 09:17 PM   #16
garyd1961
Re: Wiped a lobe.
Deleted.
Old 09-17-2018, 09:19 PM   #17
gvw5400
gvw5400's Avatar
Re: Wiped a lobe.
For what it is worth, of course a full forged everything, roller cam, roller rocker, fuel injected eta... engine is the BEST way to go.
But I've seen multiple small blocks with flat cam survive for years with a cam, lifter, timing set swap.
30 years ago I had to do just the cam lifter timing set on a 74 350 in a Blazer due to very little money. I drove it 5 more years and another 91000 miles, for a total of 266,000.
God smiled on my little family when I was down, so it is possible. If you have no other choice.
All the best, Dirk
gvw5400 is offline   Reply With Quote
Old 09-17-2018, 09:26 PM   #18
Hammond68
Re: Wiped a lobe.
Thanks for the info gvw. I'll probably change the cam out and get some more miles out of this one.
I'm thinking about pulling the distributor and priming it with a few diesel fuel washes to remove most of the shavings that aren't embedded in bearings. Use a drill as you'd do to prime a rebuild.
Old 09-18-2018, 09:54 AM   #19
volksworld
Re: Wiped a lobe.
tons of 305's lost cam lobes back in the day an no one rebuilt them....unless the oil filter clogged so bad it opened the bypass the metal should not have made it to the bearings
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 09-18-2018, 10:26 AM   #20
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Wiped a lobe.
Your definitely rolling the dice, but its your game. the L31 is the best bang for your money. I'm running one in my C30. Upgraded the CAM, holly Carb on high rise intake, electronic ignition, 2 1/4 " manifolds /dual. Pulls like a mule and runs like champ on the road.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
