09-16-2018, 11:38 PM | #1 |
Transmission Rebuild
Can anyone point me in the right direction of a quality transmission rebuild kit for a th350 in my 4x4. Also, since its in a 3/4 ton that will see tow and off road action, are there any modifications I should research more to increase reliability or strength? I think the bigger roller clutch out of a 4l60 was a good idea that I've read about a lot. Otherwise I was just thinking building stock, but not if there are some other simple things I can while I'm at it.
09-17-2018, 11:12 AM | #2 |
Re: Transmission Rebuild
you sure its a th350 in a 3/4 ton ?
th350 pan = square with 1 corner 45* cutoff . th400 pan = shape of texas . most 3/4 tons had th400 in them . but someone could have swapped it in there in the past or your doing it . as to a good bang for the buck kit look at transtar and a sk400 shift imporver kit . the kit fixes known problems but dosnt give it hard bang shifts . some good upgrades are out there . if th350 look at the solid block to replace the clunk spring . also you can swap some pistions or drums ? not sure my self . . . these will give you the option for the most clutches in them . as not all from the factory were set up this way .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-17-2018, 11:39 AM | #3 |
Yes it's definatly a th350. It must have been swapped at one point since my spid also has the code for a th400. Anyway thanks for the sugeustions. I decided to rebuild myself after the shop I talked to said they don't do th350s anymore. Said they can't compete with Summit off the shelf Trannys, since there is a summit store in Sparks.
09-17-2018, 02:15 PM | #4 |
well thats a decent reason not to do them .
but there stupid easy i have seen my friend to a dozen my self over the years . just make sure you have a few special tools and watch your self . few items under good spring pressure in there .
09-17-2018, 05:29 PM | #5 |
Yes, this body style had TH350 in 4x4 even in 3/4 ton
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
09-22-2018, 08:07 PM | #6 | |
