Old 09-17-2018, 04:42 AM   #1
Rig7
69 gmc c1500
Needing help, I replaced my turn signal switch and I have a grant steering wheel on the truck that has missing parts for the horn. The truck is a 1969 GMC C1500. The steering column is keyless no tilt Automatic on column.
So the problem I am having is when I turn on my blinker (either side) it takes them about 10 to 20 seconds to start blinking and then they start blinking slowly at first. Any ideas that would cause this?
Rig7 is offline   Reply With Quote
Old 09-17-2018, 09:04 AM   #2
geezer#99
geezer#99's Avatar
Re: 69 gmc c1500
Change out the flasher.
It’s usually on the fuse box or close to it.
Old 09-17-2018, 02:50 PM   #3
Re: 69 gmc c1500
x2. If not that, probably need to ground better. Probably a tired flasher though. Just pop it out and pop new one in
