Old 09-17-2018, 09:35 PM   #1
weim55
What lube for stock steering box??
Steering box has fill plug on my '50 but I have no idea what oil the factory specs for it? Anyone?
Thanks,
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 09-17-2018, 10:33 PM   #2
dsraven
Re: What lube for stock steering box??
you could try this,
http://chevy.oldcarmanualproject.com...esto/index.htm
maybe a different year but same style truck would give the lube type if iy doesn't show for your year. multipurpose gear lube likely, 80/90 weight gear oil. the problem is it will leak out if the bushings and seals are not in good shape. some use grease instead but that could get stiff in cold weather.
Old 09-17-2018, 11:45 PM   #3
Black_Sheep
Black_Sheep's Avatar
Originally Posted by dsraven View Post
you could try this,
If the seals are aged and leaking use white lithium grease, it stays pretty limber even in sub zero weather.
Black_Sheep is offline   Reply With Quote
Old 09-18-2018, 03:17 PM   #4
sack54
It takes 00 grease you can still find it . Or Corn Head Grease .
https://www.rcpw.com/double-0-grease/770123.html
https://www.greenpartstore.com/John-...-AN102562.html
sack54 is offline   Reply With Quote
