Old 09-18-2018, 12:17 AM   #1
ratty69
500 caddy or 455 olds?
Which one should I get?
I found a guy selling one of each. A 75 rwd 500, and a 73 455 from a 98 that will become derby cars. Either will come complete air cleaner to pan, fan to yoke and wiring. Neither has smog stuff. I've heard the caddy run long enough to drain the carb, and it sounds good. Trans wouldn't go in gear, fluid too low? Olds not running yet, but he will make it run and let me hear it.
So the caddy is cheaper upfront, but will need more parts/work to fit in my truck. The Olds should just drop right in once the frame stands are moved to the right spot.
So, assuming both run equally well, which one would you get and why? Please don't suggest LS, not happening for many reasons.
Thanks for reading.
ratty69 is offline   Reply With Quote
Old 09-18-2018, 04:02 AM   #2
mike16
Re: 500 caddy or 455 olds?
500 caddy
mike16 is offline   Reply With Quote
Old 09-18-2018, 04:20 AM   #3
Killer Bee
Killer Bee's Avatar
Dr. Oldsmobile says....
not sure what's out there for big block cad aftermarket, but used to be lots of stuff for the olds..
good luck either way!
Old 09-18-2018, 06:57 AM   #4
clay68c10
clay68c10's Avatar
Caddy! Plenty of parts available.
https://cadillachighperformance.com/
http://www.cad500parts.com/
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-18-2018, 08:21 AM   #5
1972RedNeck
1972RedNeck's Avatar
500 Caddy all day...
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 09-18-2018, 01:26 PM   #6
71cadc10
71cadc10's Avatar
if they both run equally well....same price...here would be my opinion
more displacement, and torque = Cad wins
lighter weight = cad wins
trans/convertor bolt pattern = both are same = tie (both are different than chevy)
fitment to truck = Olds may have advantage (rear sump pan needed for caddy). If you can find a rear sump caddy pan, then it would be relatively simple to put the cad in there I believe. They are both very wide units LOL
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 09-18-2018, 03:05 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Are you getting either engine after the derby is over? It's likely to be toast after a crash that destroys the radiator and the crowd wants to see the thing roll to a stop in a cloud of smoke. I'd want to hear it run after the wreck.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 09-18-2018, 03:19 PM   #8
68Gold/white
Plan on putting one in your pickup??? I'm guessing?
I believe the Cad engine is physically somewhat larger, may or may not be problem in pickup install.
Either would be good...
68Gold/white is offline   Reply With Quote
Old 09-18-2018, 06:41 PM   #9
dozerbill72
dozerbill72's Avatar
Caddy for sure. Put one in a 49 GMC 30 years ago had the power to pull anything and didn't get horrible milage either.
dozerbill72 is offline   Reply With Quote
Old 09-18-2018, 08:24 PM   #10
ratty69
Nope! He sells off the original powertrains and installs an sbc or ls for the derby; he said they run about 20 minutes without water. After they cool again they start right up.
Old 09-18-2018, 08:29 PM   #11
RustyBucket
RustyBucket's Avatar
I put a '72 455 Olds in a '79 short Silverado and it was AMAZING how much gas it burned. Serious tire burner too.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 09-18-2018, 08:31 PM   #12
ratty69
Thanks for the replies, everyone! Looks like I'm getting the caddy...
Old 09-18-2018, 08:33 PM   #13
ratty69
Originally Posted by RustyBucket View Post
I put a '72 455 Olds in a '79 short Silverado and it was AMAZING how much gas it burned...
Definitely don't want that with todays gas prices!
Old 09-18-2018, 11:24 PM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
Originally Posted by ratty69 View Post
Nope! He sells off the original power trains and installs an sbc or ls for the derby; he said they run about 20 minutes without water. After they cool again they start right up.
Does he use that engine oil that doesn't let the engine overheat after hours of driving? Are LS engines that cheap?! Man, I ought to get one for my truck.
The only experience I have with an engine locking up is way back in the mists of time (about '71) when one of my little sisters wrecked her '62 Nova convertible (45 minutes after getting her license!). We went to get another Nova with a rod knock and proceeded to drive it home (35 miles!). It got louder and louder as we drove, and it finally threw a rod, with that piston exiting the side of the block. I just kept driving it until it seized. Then my mom took me home to get the tow bar. My younger brother (who did not have a license at the time, but it was on a dirt road) had stayed with the car to keep it from getting impounded while we were gone. When we got back, it was about half a mile closer to home, because once it cooled off, it would run again. Tough little I6 Chevy. Fun fact- my dad asked me why I didn't just pull the plug wire off the affected cylinder. I was thunderstruck. We would have made it home with a lot less trouble, but I just hadn't thought of it.
~Steven
Simi Valley, CA
Old 09-18-2018, 11:54 PM   #15
ratty69
Cool story! And yes, Chevys are tough! I've never managed to seize an engine, I take pity on it and shut down before that happens.
That derby guy did show me his current car - ls powered. He said he had the ecm reprogrammed to compensate for overheating - fuel and spark curves adjust to help it run cooler. Idk the specifics, but I think the hotter it gets the richer it goes.
Computers aren't my thing, that's why I want an old school big block.
Old 09-19-2018, 12:05 AM   #16
weq92f
weq92f's Avatar
T.
Def the 500 Caddy!
Top it off with one of the available EFI systems and don't look back!!!!!!!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 09-19-2018, 10:37 AM   #17
bw46
bw46's Avatar
I would go for the big block Chevy.
bw46 is offline   Reply With Quote
Old 09-19-2018, 10:48 AM   #18
mike16
Pontiac, 428.....
Old 09-19-2018, 11:15 AM   #19
Killer Bee
Killer Bee's Avatar
^ yes! Poncho power
Old 09-19-2018, 08:20 PM   #20
ratty69
Originally Posted by Killer Bee View Post
^ yes! Poncho power
I agree. I looked for a Pontiac engine first, but they're unobtainium around here. And when you do find them, they're usually a 557 block 400...
Old 09-21-2018, 07:47 AM   #21
68C15
blood type; Retumbo
68C15's Avatar
Longhornman did a writeup on stuffing a big cad in our trucks.
Dimple (sister sledge) the driver firewall.
Rear sump pan and pickup tube
Square body towers and cad mounts.
Just use a light foot in winter. The big caddy makes big torque, NOW!
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-21-2018, 10:16 AM   #22
pat english
pat english's Avatar
If I cold get both,I would do that.They're both bop bell housing pattern.you could have one In your truck tearing it up,and one on a stand waiting to drop in.
pat english is offline   Reply With Quote
Old 09-21-2018, 10:19 AM   #23
pat english
If you want a 4 speed though,I think old's is the way to go.caddys are only automatics.
Old 09-21-2018, 05:11 PM   #24
cypressbog
Go Pack Go!
Yep. Couple other members use the 472/500 Caddie powerplant. I also recommend Caddie over 455.
cypressbog is offline   Reply With Quote
Old 09-21-2018, 07:15 PM   #25
Steeveedee
Who Changed This?
Steeveedee's Avatar
I know that one could get a manual four speed in a Calais coupe, back in the late '60s and early '70s. RARE. All the BOP bell housing and clutch parts will fit. That would be a pretty cool ride!
~Steven
Simi Valley, CA
