09-18-2018, 10:02 PM | #1 |
Has my ac been updated?
Just got a 1972 Chevy
Looking to see if this ac system has been updated? Did not get much info on the ac system from previous owner Looks like it has a updated high side charge port But the low side still has the old r12 port Here are some photos I can get better photos tomorrow Last edited by Motoman006; 09-18-2018 at 10:33 PM. |
09-18-2018, 10:14 PM | #2 |
Re: Has my ac been updated?
Flip Fa Ya...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
09-18-2018, 10:31 PM | #3 |
09-18-2018, 10:58 PM | #4 |
Who Changed This?
It has the connectors for R-134 refrigerant installed. So, probably updated.
09-19-2018, 07:05 AM | #5 |
I'd say it's been updated, it has a Sanden compressor. I'd suspect whoever did it just used an a/c machine and charged it thru the HI side.
How's it cool?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
09-19-2018, 09:04 AM | #6 | |
I unscrewed the high side cap and screwed it back on and the threads wento to far in and drained the system so I am looking to recharge it I didn’t want to stick 134a in but it did look updated and the previous owner said it was Posted via Mobile Device |
09-19-2018, 09:10 AM | #7 |
Who Changed This?
The adapter that you unscrewed should not be taken off. The proper connector on the hose should be used for charging.
Also, an AC system cannot be charged through the high side port.
09-19-2018, 09:41 AM | #8 | |
09-19-2018, 03:34 PM | #9 |
Using an a/c machine it will charge thru the high side with the compressor off. Our Robinair at work defaults to hi side charge. I usually switch it over, just in case the machine is hot or slow and won’t put in that last couple of ounces.
But.... yes you only charge thru the low side with the compressor on. Let us know how it cools when you get it going. I wonder if the PO adjusted the POA for 134?
09-19-2018, 03:41 PM | #10 | |
I’ll find out today, it worked until a few days ago I think it was my fault it leaked out So I got new seal to install on the high side plug and a adapter to fill from the low side How do I tell if the poa has been adjusted? Posted via Mobile Device |
09-19-2018, 04:10 PM | #11 |
If it has been adjusted your low side pressure will be around 26. If not, it will be around 30.
09-19-2018, 04:13 PM | #12 |
09-19-2018, 07:56 PM | #13 |
Who Changed This?
If it looks like the cans I use, that is a pressure gauge that will let you know the low side pressure during charging. It shows blue/green/red, right? You may need to put the can in a pan of warm water to help drive all the refrigerant out of it. Just watch that you don't run the pressure too high when you are doing it.
09-19-2018, 08:04 PM | #14 | |
I got it into the green and seems to be working great again Now to find out if it’ll last or there is a leak elsewhere Posted via Mobile Device |
09-19-2018, 10:19 PM | #15 |
Did you pull a vacuum or just plug that can into the port and open the valve?
Sounds like you somehow got it working again without the vacuum step! Wow! EDIT: I've done this myself with the quick-top-up kits and using the warm water to get 'em to go in... etc, but never on a system that's been completely exposed/opened up. -klb
09-20-2018, 09:01 AM | #16 | |
09-20-2018, 10:04 AM | #17 |
Who Changed This?
Back in the days before all the controls were placed on refrigerant use, we were allowed to purge the system of air by performing a "sweep". This involved charging the system with a pound or so of refrigerant and then bleeding it off. The result was a reduction in air in the system simply because there was more refrigerant in the system. Back when you could get a can for 88˘ it might have made a little sense. I never did that, though. At the time, 88˘ was still quite a bit of money to me. I have a vacuum pump, anyway.
