Old 09-19-2018, 02:57 PM   #1
Meatball
Lower Control Arms
I have a '68 step-side that I have installed a 2" dropped spindle and a CPP 3" dropped spring with 1/2 a coil cut-off. Truck sits great, but I am concerned with how close the lower control arms are to the ground. I don't have the budget for an aftermarket crossmember, so that is out.
My question is, does anyone make a "thinner" lower control arm or a tubular one that would give me a little more clearance?
Meatball is offline   Reply With Quote
Old 09-19-2018, 07:07 PM   #2
HO455
Post Whore
HO455's Avatar
Re: Lower Control Arms
Welcome Aboard!
As to your question I will guess that if you found a thinner one it may only be higher by a faction of an inch. But I would recommend reposting your question in the suspension section along with photos of how your current arm sits in relation to the ground. Someone there will know the answer for sure.
RIP Bob Parks.
Old 09-19-2018, 08:07 PM   #3
Mike C
Mike C's Avatar
How tall are your front tires? I'd be looking to have at least a 27" tall front tire and go to 28" for a little more clearance.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-19-2018, 11:15 PM   #4
popik
bigger rims and tires for sure would do the trick. Post a pic though id like to see how low it sits with that combo.
i looking to do a 2.5" front drop once i find some spindles and my front springs are unknown but dropped some for sure
popik is offline   Reply With Quote
Old 09-20-2018, 09:28 AM   #5
Meatball
They are 27" tall.
