Old 09-20-2018, 07:43 AM   #1
Franks 72
Franks 72's Avatar
Off my rocker ! 350 GM
Anyone ever had a rocker arm come off the valve? This motor was rebuild from the ground up and ran fine all last season. It has (twice ) slipped the rocker arm off the valve. Rocker nut had not backed off and preload was correctly set (hydraulic lifters). What should I look for ? Replace the lifter? Camshaft issues? Bent valve stem? Any ideas would be greatly appreciated, Im out of them. Note ,the heads are not original GM by iron "swirl" type. Thankyou
Franks 72 is offline   Reply With Quote
