Old 09-20-2018, 01:30 PM   #1
landarts
landarts
292 engine stands for K10
I am getting ready to start another new project build here soon on a 69 K10 that I picked up. The truck originally cam with a 292 motor according to SPID, build sheet and emblem on front fender. When I purchased the truck I also purchased a completely rebuilt 292 motor to go back into it and make it original again. I have done quite a bit of searching, reading threads and there seems to be a mix of answers out there. Just want to do this right one time.
So now what I have is the last P.O. removed the 292 motor at some point and installed a 327 or 350 in it. I have not removed the motor yet to verify exactly what it is. It looks like the motor perches are the typical ones that fit between the frame and are riveted on. Not like a standard C10 that has them bolted to top of frame and to the crossmember. I will be removing the motor soon to clean up firewall areas and prep for the 292 motor but need the perches and whatever else goes along to make it work. At this point I just do not know exactly what it is I am looking for.
If the items can not be sourced i dont mind fabricating whatever i need to make it work, just would love to do it the way it was back in the day if I can.
The picture below is one I found on a thread. Any direction on the subject would be appreciated.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 09-20-2018, 07:50 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 292 engine stands for K10
292s in K/ Series trucks used a diagonal crossmember. I have heard the same crossmember was also used on GMC V6s. The passenger side mount perch is unique to the 292. Drivers side is same as the other L6s.
Here's some pix of the diagonal unit. [Mine's not for sale.]
Old 09-20-2018, 10:06 PM   #3
1968k20
1968k20's Avatar
I have the "do not have these " parts for you. $45 shipped and I'll get pictures this weekend or tomorrow eve
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
Old 09-21-2018, 09:45 AM   #4
landarts
landarts
I would love to buy these from you, I will send you a P.M......thanks!
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 09-21-2018, 09:47 AM   #5
landarts
landarts
Thanks, this will be a huge step in this puzzle, I will send you a P.M.....thanks!
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
