I have a 72 c10 that I want to make look like a shop truck I want the 20 inch ridler wheels I found some that are 10 inch wide in the rear and 8.5 in the front I want to lower it no more than 6 inches just a good looking stance and drivable will those work and does it matter that they are offset like that to go 6 inches and what's the major differences in them I know there 8 inches and 10 inches so does that mean the back will stick out 10 inches wider than the front? And will they still clear everything thanks
Re: Wheels
You want 5.5 backspacing on the 20x10. And you want 4.5 backspacing on the 201x8.5. you should clear fine.
I ran these on my truck with a 5.5 drop in the front and 5 in the rear. Hear is a pic with the set up including a 1 inch spacer in the back |
