Old 09-23-2018, 05:31 PM   #1
rcazwillis
Transmission Wiring Harness
Putting underhood wiring back in Zane's 71. Turbo 400 transmission. Two wires go to the kickdown on the transmission. In the same bundle, but branching out, is 3 wires going to a flat white two plug. Wire colors are blue, brown, brown white. The two browns go to the same terminal.
I cannot figure out where this plug is supposed to go. Any ideas?
2nd question, Starter has two wires, purple and yellow. Purple is start, yellow appears to go back to gauge cluster. Is the yellow just a power feed? Why does it go to the starter. My problem is the starter I have does not have the post for the yellow wire. Can the yellow wire just go to a power feed?
Zane's 71 Build
rcazwillis is offline   Reply With Quote
