Old 09-23-2018, 08:38 PM   #1
reeltales
reeltales's Avatar
cab differences
I have a 1972 truck and found a nice rust free 67 cab.. What differences are there in doing a cab swap. I noticed so far that the accelerator pedal assembly has a different bolt pattern as well as the parking brake will not bolt up.. Can anyone tell me what other differences I am going to find? If the cabs are that different, will it be better to find a 69-72 cab instead?
reeltales is offline   Reply With Quote
Old 09-23-2018, 09:01 PM   #2
darrellyates
Re: cab differences
There are several minor differences... You can find most of them if you'll use the search engine on this site.
The doors are different... Different length of regulators, door releases are different length although the '72 doors will go on the 67 cab...
Major differences are type of e-brake. The '67 had a hand operated brake, and the '72 a foot operated unit. Also, the '72 cab had vents in the cab part of the door opening to help offset pressure when you close doors and such. "Flow-thru" was how GM advertised it I believe.
There were 2 different sized rear glass used in '67 as well. If the cab has the large window, most people would never notice the difference.
I am sure there are other differences, those come to mind immediately.
Again, use the search engine above a you'll find lots of threads. If you have access to a copy of the "Standard Catalog of American Light Duty Trucks" it documents the changes year to year.
darrellyates is offline   Reply With Quote
Old 09-23-2018, 09:30 PM   #3
1972RedNeck
1972RedNeck's Avatar
Re: cab differences
'72 has a cable to connect the gas pedal to carb whereas '67 is linkage.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 09-23-2018, 09:32 PM   #4
reeltales
reeltales's Avatar
Re: cab differences
Thanks. I had a typo error on the original.. My truck is a 71. The new cab is a 67 Large Window. I thought the doors were the same from 67 to 72 with the exception of the plastic vents in the 72 years.
Old 09-23-2018, 10:05 PM   #5
trucksntrains
Re: cab differences
71 will have a raised area for rearview mirror mounting while the 67 will not.
blue 68 c-10 work in progress
yellow/white 72 Cheyene Sold!
Green 71 Vw Bug
trucksntrains is offline   Reply With Quote
Old 09-24-2018, 11:38 AM   #6
reeltales
reeltales's Avatar
Re: cab differences
Is there any way to identify a 67 cab from a 68? Did the 68 have a hand brake like the 67? I was told the cab I bought was a 67 however, since the cab has a large back window I was thinking it could be a 68 but not sure how to positively tell.
Old 09-24-2018, 01:09 PM   #7
cypressbog
Go Pack Go!
Re: cab differences
67-68 cabs had a totally different fuse block design. Your 69-72 wire harness will not work.
cypressbog is offline   Reply With Quote
