Old 09-24-2018, 01:00 PM   #1
RyansToy
RyansToy's Avatar
Rethreading the Door plates
I noticed at least two of the door bolts started spinning.
I plan on re-threading them to 7/16 x14.
do you guys have a better or different option?
1968 GMC truck
910 Trim (Canadian)
127" WB
3 on the Three Trans (Saginaw SM330)
250 ci L6 Engine
HEI ignition (early 80s L6)
RyansToy is offline   Reply With Quote
Old 09-25-2018, 10:32 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Rethreading the Door plates
I don't think you have another option except replacing the plate, and that requires some cutting and welding. I don't know if you will have to grind the heads down any or not.
LockDoc
Leon
Old 09-26-2018, 07:50 PM   #3
68 TT
Still plays with trucks
68 TT's Avatar
Another option is to use a Heli-Coil or a solid body type threaded insert to repair the stripped out threads. This way you could keep the stock 3/8-NF threads and not have to worry about the fasteners not clearing the hinges.
The solid body type would be preferred as they are retained with tangs that are knocked in around the perimeter after you thread them in place. They are more money but would never come out with the bolt which is a possibility with a traditional style Heli-Coil insert.
I've installed literally thousands of these as an air frame fabricator and machinist for the Air Force. They are a great way to fix torn up threads in an old part.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
